Speakers or Head Unit? - JeepForum.com
post #1 of 10 Old 04-19-2009, 07:58 PM Thread Starter
SmashinTJs
My speakers seem to have died last night. They still play but you can only hear it at full volume and it sounds all treble (no bass or mid range at all) subs still hit like normal. cant think of anything to do or where to start
Help please.....?!
RED 1997 Modded TJ l 3.5 Rancho l PIAA's l 33'' KM2 l Custom Yakima Roof Setup l Armor l.
TJ TECH BOOT CAMP: READ IF NEW
Help us form the JF Search and Rescue Team
Originally Posted by scavanau View Post
Is that bumper weighted to keep you from catching air at highway speed?
Originally Posted by NorthWhiteWolf View Post
Well no (why would it) :confused:
Because I think your fender flares could easily pass for wings
SmashinTJs is offline
post #2 of 10 Old 04-19-2009, 10:35 PM
LSU_TJ
TJ Wrangler
Need a lot more detail than this. You say you have subs so you must be running at least one amp. How are you powering the speakers and what is your setup? How many speakers do you have and how many are affected? It happened all at the same time? What was happening when they died? Was it cranked up all the way or was it good when you shut it down and not when you turned it on next? What do you have in your system, type of stereo (factory or aftermarket)?
LSU_TJ is offline
post #3 of 10 Old 04-20-2009, 08:08 AM
gily25
What level/what kind of music were you listening to at the time (frequencies/volume range)? Is this an aftermarket head unit? How long was the sub installed? Are you using a LOC or is it RCA out?
If it's a recent install I would double check all wiring (guage of wire is exceptionally important). However I suspect the head unit's crossover has failed. It's somewhat unlikely 4 speakers blew at the same time from too low frequency. The sub still functions normally b/c the sub amp crossover is adjusting the signal.
gily25 is offline
post #4 of 10 Old 04-22-2009, 11:08 PM Thread Starter
SmashinTJs
problem solved. i didnt think the speakers were blown cause when i first took a look at them they seemed fine. turns out both of them are blown in the upper part of the cone.
post #5 of 10 Old 04-24-2009, 04:26 AM
keepishop
1989 XJ Cherokee
Wow, You blew a speaker to the point it was visible. How much power were you putting into those little suckers?
(Most blown speakers just melt the voice coil and refuse to more, no cone damage)
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #6 of 10 Old 04-24-2009, 07:35 PM Thread Starter
SmashinTJs
thats the sad part, i didnt even have them amped to my 1800 watt, just the alpine head unit built in amp
post #7 of 10 Old 04-24-2009, 07:59 PM
keepishop
1989 XJ Cherokee
A friend blew his front speakers that way. Most people forget to turn on a high pass filter on their midranges after they install subs, and that's what happens. Oh well, time to upgrade.
Bleed or Quit.
post #8 of 10 Old 04-26-2009, 10:03 PM Thread Starter
SmashinTJs
exactly, im savin up fo some focals
post #9 of 10 Old 04-27-2009, 08:26 AM
gily25
Listen to the focals first...they're pretty bright on the highs.
gily25 is offline
post #10 of 10 Old 04-28-2009, 11:59 PM Thread Starter
SmashinTJs
definatly will before i buy, but my subs hit pretty hard so i need a little more high to balance out the lows
What Should Come First Head Unit Or Speakers??? NCUNLIMITED Audio, CB & Ham Radios, GPS, & Electrical 8 06-04-2009 12:49 PM
CHeap head unit/ speakers 1992renegade Audio, CB & Ham Radios, GPS, & Electrical 7 05-05-2007 10:43 PM
CHeap Head Unit/ Speakers 1992renegade Audio, CB & Ham Radios, GPS, & Electrical 10 05-03-2007 09:22 PM
Marine Head Unit and Speakers? NinjaTurlteSean Audio, CB & Ham Radios, GPS, & Electrical 15 07-10-2006 06:41 AM
Installed new head unit and speakers. eruji Audio, CB & Ham Radios, GPS, & Electrical 19 04-17-2006 10:07 AM
