Speaker Upgrade - Need Some Help! - JeepForum.com
post #1 of 21 Old 02-29-2012, 11:33 AM Thread Starter
PCfirefighter
Have a '99 TJ ... New Owner of a Jeep
Looking to upgrade speakers all around.
Dash Speakers: Would anyone suggest going from 4x6 to 5.25? I know I would need a adapter. Does it sound better? Would any suggest component for the dash speakers or straight 5.25
Sound bar : Its a 2 speaker sound bar with 5.25 in them. I def want to upgrade these. Stay with 5.25 or go 6.5? I do want to component, so is it easy to add the tweeter? There is padding around the sound bar, and I guess i will have to cut into it.
I am upgrading by head unit and already been purchased.
PCfirefighter is offline
post #2 of 21 Old 03-01-2012, 08:10 AM
NalinMFG
PCfirefighter,
I may be slightly biased towards 5.25"s in the dash, but I love them. 6.5"s are the way to go in the sound bar. Below is a link with several customer reviews if you are looking for some first hand experience with 5.25"s in the dash.
http://www.jeepforum.com/forum/f43/t...inmfg-1325275/
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #3 of 21 Old 03-01-2012, 01:12 PM
enjoislipknot
Why not go the right way and get 5.25 in back and 4x6 in the dash...then say two tens in the back or a single ten. dont mess around with "bass" be bumping!!
enjoislipknot is offline
post #4 of 21 Old 03-01-2012, 01:35 PM
gily25
The right way would be 4 matching speakers or a properly amped front stage; not 4x6" speakers.
I say go with 4 5.25" If you're adding a sub and the 6.5" in the soundbar if you're not. You don't really need components...amplifying the dash speaker gives a better result.
iPhone app user; excuse typos...thanx.
gily25 is offline
post #5 of 21 Old 03-01-2012, 01:51 PM
bobthetj03
What gily said. 5.25's in the sound bar works fine too. They are so close to your ear they are only good for fill IMO. Fade the sound bar's down and focus your sound stage on the dash speakers. Put some foam enclosures behind the dash speakers for a little added clean.
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #6 of 21 Old 03-01-2012, 02:20 PM
NalinMFG
Care to elaborate on your "right way" theory?
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #7 of 21 Old 03-01-2012, 03:41 PM Thread Starter
PCfirefighter
Thanks for the info guys! ....
post #8 of 21 Old 03-01-2012, 04:50 PM
enjoislipknot
Well eh my right way would be a mono block amp and 2 channel amp with probably a good 0 ga. Wire set pretty good hu with pre amp outputs and a couple tens considering that's all the bigger you can fit in a jeep. But I just don't think 5 1/4 are very sufficient for bass..technically they are mid range.. that's def. My opinion but I like good bass with good treble as well.
post #9 of 21 Old 03-01-2012, 05:57 PM
terpsmandan
2009 JK Wrangler
i had the pods in my 05 and replaced the OEM speakers with infinity 4". I used the adapter brackets in my 00 and they were ok but i traded that one in on the 05 that I have now. When I went to upgrade the speakers, I tried the 5.25 brackets and the tweeters were buried behind the dash and didn't sound that good so I used the pods and it was a huge difference.
terpsmandan is offline
post #10 of 21 Old 03-01-2012, 07:18 PM
gily25
I don't think anyone was tryin to substitute midrange speakers for sub bass...Most people want to replace their scratch paper oem junk...we help with the sizes and hope they audition speakers to pick the right brand.
I've seen 4 15's in a jeep each with their own amp...profile on car domain actually saw the vehicle in Miami. There are a few jks with fiberglass craziness that made the show circuits in 2008ish. It's usually overkill...most listeners would be fine with an 8" near them (look at how many people are happy with their upgraded center console sub. Others have no interest or money for a sub...for them spending money on a quality set of midrange speakers is the best route.
For those who want more, a good quality 10 or 12 in the right enclosure backed with rms at the high end of the subs handling will hit harder than expected for a jeep.
The reason to pair the subs with a decent front stage; 5.25's, amped is better is because if you're investing all that money and running quality threads you might as well have some lyrics with your bass.
I guess it depends on whether you dig SQL or spl.
gily25 is offline
post #11 of 21 Old 03-01-2012, 07:55 PM
enjoislipknot
I guess I dig spl and sq
post #12 of 21 Old 03-01-2012, 08:22 PM
NalinMFG
Correct. Factory 4"x6"s are junk, and unless you buy another junk replacement from the dealer, you need some form of an adapter to go 4"x6" or 5.25". Perhaps I misinterpreted what you were getting at...I thought you were suggesting that a 4"x6" is a better choice than a 5.25".
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #13 of 21 Old 04-13-2012, 11:17 AM
patman2k
Polk makes some 50w 4x6's that are great for the dash speakers. They are also marine grade, so they won't mind getting a little wet. The 40w have the tweeter that sticks out too far and they won't mount properly without spacers.
patman2k is offline
post #14 of 21 Old 04-16-2012, 06:09 PM
Nyteryder3
for my money the best thing i have found is to keep the stock 4x6's in the dash and upgrade the rears to 6.5's. I also added the sky-dock with two 4"s that have made a huge difference. I also added a 10" subwoofer in the rear. all in all my system sounds solid. The sky-dock does a great job of sending sound directly to you and the passenger.
Nyteryder3 is offline
post #15 of 21 Old 04-17-2012, 08:12 AM
freeskier93
4x6 and 6.5 is a pretty large size gap. As all ready said the best set up will come from having speakers all the same size. IMO the best set up for a Jeep is 5.25" all around with a sub (all amped of course). Personally I have infinity kappa 5.25 in the front and 6.5" in the back because I don't want a sub taking up space and figuring out where to put another amp that wont die from water. For me the bass is fine.
I have the nalin brackets in the front with coax speakers. If I were to do it again I would also get the nalin tweeter brackets and components. Right now the front highs struggle because the dash speaker covers are so stifling and point sound down.
freeskier93 is offline
sound bar , speaker , speaker replacements , speaker size
help w/ speaker upgrade no amp wrscpc07 Audio, CB & Ham Radios, GPS, & Electrical 13 02-10-2012 03:24 PM
Speaker upgrade in 97 TJ seaeagle Audio, CB & Ham Radios, GPS, & Electrical 56 04-26-2011 07:41 PM
speaker upgrade RickyLisk Audio, CB & Ham Radios, GPS, & Electrical 0 10-19-2010 05:13 PM
Speaker Upgrade TylerFlip Audio, CB & Ham Radios, GPS, & Electrical 10 10-17-2009 08:47 PM
speaker upgrade for under $100 bikerack Audio, CB & Ham Radios, GPS, & Electrical 8 05-17-2005 10:12 PM
