Speaker issue. New db521 crackling. Not the speaker - JeepForum.com
post #1 of 8 Old 09-08-2012, 02:03 PM Thread Starter
cinciwat
Replaced dash and soundbar speakers with DB521 Polk 5.25 inch. They sound awesome but... One of the soundbar (passanger side) speakers positions is static/crackling. It is not the speaker because i swapped one of the other new speakes in the same soundbar spot and it had the same issue. The other three are fine. Great in fact!
What could the issue be with that one soundbar speaker hookup? Wondering where to start looking.
cinciwat is offline
post #2 of 8 Old 09-09-2012, 06:25 AM Thread Starter
cinciwat
Come on people. I have fixed every problem i have posted. Someone has to have had this issue. The problem stays in the one soundbar casing. Swapping speakers around the issue does NOT follow the speaker but remains in that spot. I have reversed the + and - and looked for anything else. Both dash and other soundbar sound awesome so just need an idea of what this could be. Before i take it apart would like some expert advice on where to start.
cinciwat is offline
post #3 of 8 Old 09-09-2012, 07:01 AM
Ironhead
wow, calm down there speedy, this section doesnt get as much traffic as others. and fixed every problem you have posted? you have 9 posts
i have the same issue, found that if I touch the light next to the buzzing speaker, it sounds perfect. havent gotten around to dropping the speaker and finding a solution, but it is probably the light
Ironhead is offline
post #4 of 8 Old 09-09-2012, 01:52 PM Thread Starter
cinciwat
Nice ironhead. Never been patient. Not speedy either. Just a little torked i dropped the $$ and time to put 4 speakers and subwoofer in only to have the one pesky issue.
You were right. For some reason the light was causing the static. Took the light out and pulled wires back and the static is gone. I cut the origional tape away that was holding them together and taped the light wires seperate from the speaker wires starting at the entry point. Hooked everything back up and sounds fine.
As for the nine posts. You have to start somewhere. Now at 10. BAMB!
cinciwat is offline
post #5 of 8 Old 09-09-2012, 03:13 PM
Ironhead
thanks for the info, it's annoying as hell and i havent had any time. i thought i blew one of my polk momo's and was messing with everything. touched the light and fixed everything. good to know that all i need to do is tape up the wires. i was waiting to open it up cause i am going to add some floss too
Ironhead is offline
post #6 of 8 Old 09-09-2012, 06:01 PM
mKosel
What light? (car noob speaking)
mKosel is offline
post #7 of 8 Old 09-09-2012, 08:58 PM Thread Starter
cinciwat
The light i am talking about is in the soundbar. My soundbar has a dome light next to the speaker and inside the casing the wires were taped together.
cinciwat is offline
post #8 of 8 Old 10-02-2012, 11:00 AM
Ironhead
did that permanently fix the issue? I dont use the factory speaker wire, so i just taped the pigtail to the light wires. it was better, but still had some vibrations. ended up making a gasket out of a bud light case, and fit it between the light housing and the speaker pod. no more vibes, and only a few minutes of work
Ironhead is offline
