spark plug change - JeepForum.com
post #1 of 4 Old 08-21-2005, 12:32 PM Thread Starter
01jeepgrand
spark plug change
New user here, is there a section for dyi? If not any suggestions for info for changing spark plugs on an 01 grand cherokee? Also recommended plugs?
01jeepgrand is offline
post #2 of 4 Old 08-22-2005, 10:23 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Which engine?
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #3 of 4 Old 08-22-2005, 05:54 PM Thread Starter
01jeepgrand
sorry, it is the v6 4.0 liter
post #4 of 4 Old 08-22-2005, 06:46 PM
Jerry Bransford
Administrator
Ok. Just to let you know though, the 4.0L engine is not a V6, it is an I6, which just means it is an inline six-cylinder engine... all the cylinders are in a row, not three on each side like a V6 would have. No worries though, even those that might know it is an inline-six cylinder engine still often just call it a V6 out of habit.
The spark plugs are underneath a plastic cover that covers the ignition coils and plugs for that engine. They are on the passenger-side of the engine block and are pretty easily changed once you get the plastic cover removed. Take a look, you should find that they're fairly easily changed.
Avoid gimmick plugs like Splitfire and Bosch Plus2 and Plus4 plugs, they just don't work well in that engine. Stay with good quality plugs like Autolite, NGK, Champion, etc. and you'll be fine. Gap them to .035 if they're not pre-gapped which most are now.
Getting
4.0L Spark Plug Dilemma gmcd Engines & Drivetrain 7 08-12-2009 08:14 PM
Spark plug Change then missfire starts...HELP! unlimited4x4 Engines & Drivetrain 6 09-14-2008 09:36 PM
spark plug change question... 1994Wrangler Engines & Drivetrain 3 04-10-2004 09:26 AM
Spark plug wire. 1994Wrangler Engines & Drivetrain 10 09-19-2003 04:32 PM
spark plug gap badams Engines & Drivetrain 5 07-20-2002 07:59 AM
