Soundbar = No Rollbar Padding? - JeepForum.com
post #1 of 6 Old 06-05-2007, 08:47 PM Thread Starter
Armitage
Can you keep your rollbar padding with an OEM soundbar or is it necessary to trim/remove it for install?
Scott - '98 TJ (Purchased 11.2006) - 131k Miles (20k mine)
Looking for a good deal on rims, tires, or both!
Armitage is offline
post #2 of 6 Old 06-05-2007, 10:13 PM
surfer23505
Mine came from the factory with it so off the top of my head i believe it is just cut short to make room for the sound bar so if you are adding one you might need to cut it back some.
surfer23505 is offline
post #3 of 6 Old 06-06-2007, 06:37 AM
Combatsylvania
ndbar fits over the padding.. there is just a few holes for the screws and wires to go through
2006 TJ SE - Does what I want it to do.
Combatsylvania is offline
post #4 of 6 Old 06-06-2007, 02:20 PM Thread Starter
Armitage
Ok thanks. I didn't notice any holes in my padding but I'll look again.
Armitage is offline
post #5 of 6 Old 06-06-2007, 06:34 PM
surfer23505
Just looked at mine to confirm what it was like and yes on mine the padding ends before the sound bar and it might need to because from what i can tell without taking the sound bar off is that there is a grove on the roll bar that it fits into and then the sound bars padding raps around the roll bar so it is not exposed. So thats just how mine is so hope that helps
post #6 of 6 Old 06-08-2007, 07:43 AM Thread Starter
Armitage
Well my problem is a bought a sound bar used but its from a YJ, not a TJ and it looks to me like its not a direct bolt-on. The brackets don't seem long enough on both sides for the soundbar to lay perfectly onto the roll bar.
Armitage is offline
painting rollbar padding? - can this be done? jousley Cheap Tricks & Fixes 65 03-24-2014 09:27 AM
getting mud off rollbar padding & seat belts?? BNovak General Jeep & Off-Road Equipment 11 05-28-2009 01:15 PM
painting SFI rollbar padding? UTmike General Jeep & Off-Road Equipment 0 03-09-2009 10:47 PM
Roll Bar Padding jrs948 General Jeep & Off-Road Equipment 14 08-28-2008 05:40 PM
Who has a soundbar.......roll cage padding? GoTopless Audio, CB & Ham Radios, GPS, & Electrical 8 07-26-2003 10:38 PM
