Quantcast Sound System Installation Questions - Page 9 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Sound System Installation Questions
Old 02-04-2008, 12:39 PM   #121
usurp
btw, whats the Pre-Out for on my Alpine amp?
2004 Jeep Wrangler Sport
Light Khaki | Hard Top | 6-cylinder 4.0L | 3.73 gears | Dana 44 | Trac-Lok LSD | 2.5" OME suspension | JKS 1.25" BL and MML | JKS Quicker Disconnects | JKS adj. front trackbar | 33x12.5 Hankook DynaPro | Cragar 342 steelies | Alpine iDA-X001, Four Boston SX55's | Infinity BassLink II. Click here for pictures.
usurp is offline   Reply With Quote
Old 02-04-2008, 12:40 PM   #122
SirGCal
SirGCal's Avatar
Ahhh.. What does it sound like if you turn the crossover's up? Does it get too boomy or does that fix your problem? (say 200Hz).
Sir G. Cal - 2k Sahara TJ
Living and loving on borrowed time. Life with Multiple Sclerosis. My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline   Reply With Quote
Old 02-04-2008, 12:41 PM   #123
SirGCal
SirGCal's Avatar
to jump to another amp.
Old 02-04-2008, 12:46 PM   #124
usurp
it gets boomy. I thought by turning the crossover up it would solve my issue but it didn't.
Btw i was checking out the pictures of your 2004 install. Did you have any vibration problem with the cover of the light in the pods. My left pods light cover rattles sometimes, I am thinking of putting silicon around the edges..
Old 02-04-2008, 12:50 PM   #125
SirGCal
SirGCal's Avatar
yup, and that's pretty much what I did. Just a drop or you'll never get it off again to replace the bulb.
Ok... Next question. Does your Alpine have built-in filters? Are they turned on? (they shouldn't be since we're using the amp's).
Old 02-04-2008, 12:55 PM   #126
usurp
What do you mean built in filters?
In my Audio Settings I just have Equalizer (there are a number of presets i have mine to flat)
There is MX Setup (I have it off)
There is Subwoofer On or Off, I have it on
Then there is subwoofer reverse something. I have it set to normal although i tried reverse and nothing changed.
Old 02-04-2008, 01:02 PM   #127
SirGCal
SirGCal's Avatar
My Alpine has built-in adjustable crossovers. I'm asking if yours does also or if it has some other bass filtering feature for the fill speakers built in. Something else you could test easily is turn the other amp from hp to ap (all pass) basically turning the filter off. Turn off the basslink for this test. Do the speakers seem to be playing full range? If not; there's some other filter on them. I don't think the SX's have a high-pass for the woofer itself, just one for the tweeter. But that's also possible. Haven't seen one from this-year's lineup. But they have a good frequency response so I wouldn't see why they would even want to put one on... (especially a first-order that would be in the basket like that).
Old 02-04-2008, 01:07 PM   #128
usurp
ok I will try that now and get back to you. give me like 10 minutes.
Old 02-04-2008, 01:37 PM   #129
usurp
ok back. I think i found out the problem, its with the equalizer.
I first did what you told me about turning off the high pass, didn't really do much, the music sounded bad. I played around with different settings for the crossover and gain to no avail. anyway I then decided to try the equalizers and once I put the setting to "Rock" the sound came to life. I then turned the subwoofer on and it was loud. When i turned the subwoofer level all the way down to 0 it was still loud, i actually had to lower the gain and bass boost on the basslink.
The music sounds much fuller now. I still need to work on it a bit more, i think i need to increase the gain on my speakers a little bit and maybe turn up the crossover slightly but at least I am getting somewhere. I can't believe what a difference this made.
Old 02-04-2008, 04:37 PM   #130
bman9089
You get what you pay for
bman9089's Avatar
Good reading here.
keep us updated. The midrange response is something I'm worried about too. Or maybe higher bass notes, anyways, that's what I'm getting at. That's what I'm most worried about.
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain
† Christian Jeep Club †
Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38
bman9089 is offline   Reply With Quote
Glock Forum
