Quantcast Sound System Installation Questions - Page 3 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Sound System Installation Questions
Old 01-07-2008, 02:43 AM   #31
usurp
Well I live in Kuwait and theft isn't an issue here, I've seen a guy leave his lamborghini running with the door raised open and go into a convenient store.
My rear seat is always in, I've never removed it but when I go to the supermarket or when I have my dog in the back I just raise the seat.
I think I am going to do what you suggested and get a small metal covering fabricated to cover the amp. I think that would solve my concerns, it would protect the amp from groceries, drool and stuff banging into it.
I always take lots of pictures and try to name them properly like "alpine-f250-amp-location-2.jpg" so that if someone using google images tries to find a picture of the amp they can find it. Will also take pictures of the whole installation process from beginning to end so it can be helpful to forum members.
BTW, it seems like so far nothing is going according to plan. You know the picture of the grommet behind the brake pedal which PJL posted above, I checked mine yesterday and I have a ton of wires going through it! I need to see if I can fit two power cables through it or find another entry point.
2004 Jeep Wrangler Sport
Light Khaki | Hard Top | 6-cylinder 4.0L | 3.73 gears | Dana 44 | Trac-Lok LSD | 2.5" OME suspension | JKS 1.25" BL and MML | JKS Quicker Disconnects | JKS adj. front trackbar | 33x12.5 Hankook DynaPro | Cragar 342 steelies | Alpine iDA-X001, Four Boston SX55's | Infinity BassLink II. Click here for pictures.
usurp is offline   Reply With Quote
Old 01-07-2008, 07:37 AM   #32
SirGCal
SirGCal's Avatar
Originally Posted by usurp
I called the dealer and asked for a seat bracket. Told me it would cost around $700 because it comes as "full set". I told him I have the seat and i have the car i just need the thing that connects the two together. I don't think he knew what he was talking about.
Anyway spoke to a friend, I am going to a junkyard this weekend.
Tell them you're looking for the 'seat risers'. I had to order the factory ones from the 97 TJ parts book (only one that had the part number oddly). Find someone with the parts manual and they might be able to look it up. But it's just the two black things in this picture of the bottom of my seat during construction:
And here they are installed from the door's point of view (well one of em anyhow). Again, just the black metal part.
They were ~ $38 each or something of that nature; not no $700... Wounder what they're smoking...
Sir G. Cal - 2k Sahara TJ
Living and loving on borrowed time. Life with Multiple Sclerosis. My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline   Reply With Quote
Old 01-07-2008, 11:17 AM   #33
usurp
Ok some more updates.
This is how my grommet looks like, lots of cables going through so I need a new point of entry for my power cables, any tips?
After that I started figuring out how I was going to wire my new speakers into my pods so I removed the factory speaker which is really crap and looked behind it.
When I removed it I found the cable going through the pod via a small tube. I doubt I am going to be able to squeeze my new cables through that, I will try but I might have to drill a tiny hole in the pod.
The cable then travels from the right pod towards the left one traveling on top of the roll bar. Once it gets to the end it comes down behind the drivers seat where it joins the cables coming from the trunk.
I noticed also that gas tank is located underneath the trunk where i will be mounting my amp. Will it be safe to drill a hole? I mean how far is the gas tank from right underneath the area I will be drilling? I think I will try to find the seat risers but just in case I will have to drill in the trunk...
Oh and I think I will for sure have to remove the roof and rear seat during the installation. Its just too claustrophobic if i dont.
Old 01-07-2008, 05:13 PM   #34
bman9089
You get what you pay for
bman9089's Avatar
Mine is being used also. Drill a couple of holes just like that (or even one larger hole) use a rubber plug and run wires through that. That's what I'm going to have to do. I think Crutchfield sells them. I'm sure www.partsexpress.com has them, they seem to have everything.
oh yeah, you aren't the only ones with problems. Trust me, my build isn't going smooth either. But I'm still learning a lot of tricks in the process.
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain
† Christian Jeep Club †
Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38
bman9089 is offline   Reply With Quote
Old 01-07-2008, 05:16 PM   #35
bman9089
bman9089's Avatar
I wouldn't want too, nor risk drilling the trunk area. You can't slide a bracket under those hooks protruding from the tub and attach it that way with screws? I think that would be easier. Plus, the gas tank is tricky. I installed a bumper yesterday and it was scary drilling out the rear cross member because of the plastic tank behind it.
Old 01-07-2008, 08:25 PM   #36
PJL
The first time I installed my amp it was in that location. As long as you're careful (not jeweler careful, more like not negligent) you won't puncture your gas tank. There's a gap between the body and the gas tank. I had the drill bit go through about 1/2" and it didn't hit anything.
PJL is offline   Reply With Quote
Old 01-07-2008, 11:54 PM   #37
02tjsport
You should have an UNUSED super thick grommet behind the engine on the firewall, it comes in just to the left-center of hte dash but only a few inches from where the tranny tunnel meets the firewall. It is easy to cut or drill into.
'02 TJ Sport - 3.5" RE Springs/Mono-tubes; BFG A/T 33x12.50x15 on ProComp Black Steelies; JKS: BPE's, 1.25" BL, shock conversion, front Adj. TB's, quick discos, Extended Brake lines; FT 3-link rear; JCR 1-ton Steering; Warn 6" Flares; Olympic Slider Bumpers; OME SS; Taurus Electric Fan; 4.88 Gears; D30/D44 Detroit True-Trac Front/Rear;
02tjsport is offline   Reply With Quote
Old 01-07-2008, 11:56 PM   #38
usurp
I am heading out to the junk yard on Thursday morning, hopefully will get lucky and find a seat riser. If I do I won't have the need to drill in the trunk.. for now, I still would need to drill later to mount the BassLink.
Old 01-08-2008, 12:03 AM   #39
02tjsport
If you havent bought any cables yet, i just bought some MONSTER brand RCAs as well as a JL Audio amp wiring kit on ebay for 1/3 of retail price.
4 channel Monster RCA 6M length (their XLN line) $46 shipped
JL audio 2 amp kit (4ga. with 8ga. splitter) $75 shipped
I got a 2 channel Monster RCA 6M length (sub specific rca, XLN line as well) from procura.com for $62 I paid extra for shipping, i think ground shipping (state side) was only like $7
Old 01-08-2008, 02:51 AM   #40
usurp
i paid 87$ for a streetwires multiamp kit with shipping from amazon.
http://www.amazon.com/gp/product/B000P709D6
I think i saw the large grommet you are talking about. I took a picture of it will post it when I get home. When looking from under the dash on the driver side the grommet is up right, its a black round plastic thing i think. I noticed it and took a picture of it but I didnt know what it was.
Old 01-08-2008, 11:53 AM   #41
02tjsport
Yea that should be, you can see it from the engine bay as well. i grabbed it from the inside with pliers and someone else pushed on the rolled edges of it from the engine bay with a screw driver
Old 01-08-2008, 01:22 PM   #42
usurp
02tjsport which of the following is the grommet you are talking about?
First one:
Second one:
Old 01-08-2008, 01:33 PM   #43
02tjsport
im thinking it is the first one, but on my buddy's 05 it was unused. On my 02 it was unused.
i cant tell by looking where the 2nd one is, it seems as though it is up above the steering column. i used that for my reverse lights.
Old 01-08-2008, 01:58 PM   #44
usurp
I think the second one if behind the middle of the dash. I think I am going to use the first one, will just cut through it and when done just cover it with duct tape.
Old 01-10-2008, 03:28 AM   #45
usurp
I just got back from the junkyards awhile ago. I found two junkyards that had the seat riser I wanted, the first place would only sell me all three seats of the wrangler together and the second place wanted me to buy the full driver seat. They both wouldn't sell me just the riser by itself.
I haven't given up though, I will pass by the dealer on Saturday and try to see if they just have the seat risers by themselves. I am sure they misunderstood what I was looking for when I spoke to them on the phone.
Glock Forum
