Sound Processor '12 JK - JeepForum.com
post #1 of 3 Old 07-14-2012, 12:54 PM Thread Starter
TheCrut
I'm looking at upgrading the stock stereo with a sound processing unit, amplifier, speakers, and sub. I read a post a while back Here that talks about upgrading the stock head unit with a sound processor. The premise is that the stock head unit cuts low frequencies or shapes the sound to make the stock speakers sound better. When aftermarket amps are installed, it's crap in and crap out.
I took to some engineering skills and hooked up my laptop running some free real time analyzer software and playing some pink noise through the CD player, and found that this just doesn't seem to hold up (see attached picture).
The problem is, my laptop has a sucky sound card, so I couldn't get any higher than volume level 6 before it started clipping the signal, so I can't get any idea of how the frequency response changes at higher volume levels (you know, like the ones I listen to). I know that some stock manufacturers cut the bass at higher volume levels.
Rather than spend the money on a good RTA or soundcard, I'm taking to the forums to see if anyone has done this test already and could share the results. Do I need to spend $300 on the JL Cleansweep, or can I get by with a less expense line output converter?
TheCrut is offline
post #2 of 3 Old 07-14-2012, 09:41 PM Thread Starter
TheCrut
Update
Success! I just added about 100k ohms resistance to my measuring circuit and was able to get around that pesky sound card clipping.
The results are still very good. At volume level 22, the spectrum is still very flat with the exception of the super low range, though 20Hz by itself comes through nicely. I would say we are fortunate with the stock system that doesn't shape the waves.
That being said, anyone have good luck installing an amp with speaker level inputs, or should I still be trying to get a line converter?
TheCrut is offline
post #3 of 3 Old 07-15-2012, 06:49 PM
CrutchfieldMark
I think if you used a lower cost line level converter, you're still going to get an improvement in sound replacing the follow on factory components. I think factory h/u's have gotten much better over the last few years and not at just adding features. Just my two cents worth.
What fits your Jeep?? Find out below!!
CrutchfieldMark is offline
jk , stereo system , stock head unit
TJ: Installed Alpine IDA-X100 and PXA-H100 Sound processor deltabravo Audio, CB & Ham Radios, GPS, & Electrical 6 02-28-2009 06:53 AM
Sound Bar/Sound Pods? Factory Radio Wattage? 05 TJ DJMunich Audio, CB & Ham Radios, GPS, & Electrical 7 01-03-2007 07:07 PM
My VDP problem adding sound bar and sound wedges jbggump Audio, CB & Ham Radios, GPS, & Electrical 3 11-09-2006 02:07 PM
Soundstream Processor mpala96 Audio, CB & Ham Radios, GPS, & Electrical 1 10-27-2005 11:30 PM
Sound system for 2002 wrangler w/ premium sound Bryan_16 Audio, CB & Ham Radios, GPS, & Electrical 2 05-31-2002 09:17 PM
