Sound bar and 6.5" speakers. I read I may have problems with the stock head unit. - JeepForum.com
post #1 of 5 Old 12-17-2009, 04:03 PM Thread Starter
rbwamsley
Tj Sound bar and 6.5" speakers. I read I may have problems with the stock head unit.
I just bought these speakers (see link below) and I read that I may have some issues pushing them with the stock head unit. Could someone please explain to me why?
Speakers
Amazon.com: Polk Audio DB651 6.5-Inch Coaxial Speakers (Pair, Silver): Electronics
Thanks in advance,
Blake
2005 Jeep Wrangler X - Electric Lime Green
2.5" Rough Country Suspension Lift : 1" Body Lift : 1" JKS BMML : RC Adj. Front Track Bar : Rough Country Steering Stabilizer : 33x12.50R15 BFG All Terrains on Black Steelies
rbwamsley is offline
post #2 of 5 Old 12-17-2009, 04:32 PM
ihatefruitloops
because they handle 60 watts and your stock headunit will only puch about 10 or so to them
ihatefruitloops is offline
post #3 of 5 Old 12-17-2009, 05:24 PM Thread Starter
rbwamsley
I understand that, but I have never heard of any issues with under powering a speaker. The only thing I see is that they wont be at their full potential. Am I missing something?
post #4 of 5 Old 12-18-2009, 08:48 AM
SirGCal
RIP
SirGCal's Avatar
Well, it's a multi-part problem.
Underpowering speakers does a few things, but in and of itself isn't bad. It's these other things that become bad.
Simply, the speaker can't be controlled by the weak power source. Think of trying to drive a dump truck with a dirt-bike engine. You might actually get it to move, but not very well. At low volumes, this is fine and the speaker will do well. But when you start to try to push your volumes, the speaker's power-hungry nature will cause the power source to lose accurate control of the speaker. This can result in things like early distortion, added noise, all the way up to clipping and coil distortion that can actually damage the speaker.
The inverse (putting way too much power behind a speaker) is like putting a top fuel dragster engine in an otherwise stock sedan. First time on the gas hard, you explode parts left and right.
The perfect balance is giving the speaker the power it wants to properly operate without cooking it.Target is say 80-110% it's rated RMS potential. So with that speaker being rated 60W RMS and most of the stock TJ units I tested only having about 7W of output, you can see you're grossly underpowered. This is fine if you don't crank it. But if you try to boost it (even loud enough for topless on the highway may be too much), you'll eventually run into problems. Plus it will just generally sound bad at volume since you don't have the power to actually move the speaker.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #5 of 5 Old 12-18-2009, 09:11 AM Thread Starter
rbwamsley
Thank you for the info. I really appreciate it!
replacing stock 4x6 & 4" & head unit, help!! Taurin23 Audio, CB & Ham Radios, GPS, & Electrical 4 04-09-2009 01:24 PM
New Head Unit + no sound from stock sub phenamunan Audio, CB & Ham Radios, GPS, & Electrical 11 12-07-2008 01:57 PM
TrailRock - Best Speakers for Stock TJ Head Unit? JBWood05TJ Audio, CB & Ham Radios, GPS, & Electrical 16 05-10-2008 07:26 PM
Upgrade speakers with stock head unit on TJ VinoTJ Audio, CB & Ham Radios, GPS, & Electrical 1 08-01-2006 02:52 PM
Need specs on stock head unit in 2002 wrangler with sound package Bryan_16 Audio, CB & Ham Radios, GPS, & Electrical 0 06-03-2002 08:21 PM
