Someone answer a few electrical questions please! - JeepForum.com
post #1 of 7 Old 09-23-2012, 09:33 PM Thread Starter
Skytard
This is not jeep related.
My mom is starting a food truck business and I'm building the truck. I just have a few electrical questions.
We have a 7500w generator that is going to be powering everything. I've been doing some math to figure out if 7500w is enough. Tell me if my calculations are wrong or if I'm not considering something.
If a machine's requirements are 240v, 4.7kw, 20 amps does that mean it takes 4800 watts?? (240volts x 20amp = 4800 watts)
I shouldn't need an inverter, should I? If you can plug into a generator than that means it already has one, right?
Anything helps, thanks
Poor college student.
Skytard is offline
post #2 of 7 Old 09-23-2012, 09:41 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Gour math is correct. You do not need an inverter unless you're going from AC to DC or DC to AC. Do you need power for anyghing other than the 4800 watt load? If you do you need to take that into consideration as well.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 7 Old 09-23-2012, 09:59 PM Thread Starter
Skytard
Yes I do but nothing big. I shouldn't go over 80% of max wattage though, which is 6000. If we do, I will be upgrading the generator.
Thanks for answering my question
Skytard is offline
post #4 of 7 Old 09-25-2012, 03:24 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
4.7kw = 4.7 kilowatts = 4700 watts
Be careful if you're not really familiar with what you're doing. Simple electrical oops kill people.
Test Questions:
Should the truck chassis be bonded to the generator electrical ground?
Is any GFI protection needed?
***Chris***
chris87xj is online now
post #5 of 7 Old 09-27-2012, 02:19 PM
FastHotRod
Correct, assuming that it is at unity power factor. At a power factor of 0.8, you're looking at about 3.84 kW.
If it is a motor load, then factor about 6 times the locked rotor current for initial starting capacity... otherwise, you should be good to go.
Technically, no. A generator is by itself an alternator driven by an engine. An alternator creates AC power. (Alternator = Alternating Current = AC power.) So if your devices are powered by 120 VAC or 240 VAC, then you simply need to wire them up accordingly. No additional 'inverter' is required.
An inverter is a device that takes a DC input and then "converts" it to AC power. You can see these all over the place... in cars, Jeeps, trucks, semis, power systems, etc... It takes your vehicles DC system and makes AC to power various devices like TV's, radios, tools, etc...
A rectifier is the opposite; it takes in AC power and "converts" it to DC power, much like a battery charger does.
The UPS that sits under a desk and keeps your computer on? It has a rectifier, a battery, and an inverter. AC ---> DC ---> AC. When the power goes out, the battery is already on and keeps the inverter running until commercial power comes back on. When it does, the rectifier powers the inverter AND charges the battery for the next outage.
Make sure to balance the loads between the phases so it runs smoothly. Most small generators like those have two "phase legs" that each produce 120 VAC each, 180 degrees out of phase from each other.
Phase A <-----> Neutral <-----> Phase B
120 VAC -------- Neutral --------- 120 VAC
----- 120 VAC + 120 VAC = 240 VAC -----
It's correct to call it 240 Volt single phase, but just remember that you are technically using both legs to get the voltage. The remaining 120 VAC devices need to be split up between A-N and B-N such that the overall loads are balanced. If you don't, then it's like riding a bicycle with a bent pedal... it's gonna shake and not be smooth.
Chris is right regarding the wiring... you don't want to make an 'oops' so be sure to consult the NEC (or a local engineer/electrician) for guidance. You'll want to focus on the whole "neutral/ground bond" and see how it applies to the vehicle. A vehicle is normally insulated from the earth via the tires, but you don't want to have a potential difference between the earth/chassis parts/human... that could create a situation where two parts on the truck are at a different potential (voltage) that could kill someone.
Using metal conduit is a good idea, and grounding the conduit will help prevent bad things from happening. Using a GFCI circuit breaker at the generator would be able to detect if you had and current from the phases not returning through the neutral, or going through the ground (chassis) or a human.
Good luck.
FastHotRod is offline
post #6 of 7 Old 09-27-2012, 09:39 PM Thread Starter
Skytard
Thanks everyone for you answers!
Skytard is offline
post #7 of 7 Old 09-28-2012, 05:32 PM
w1pf
Who, me?
w1pf's Avatar
2007 WK
Generator ground needs to be bonded to vehicle ground.
Wire the AC circuits like a house, not like a car.120V isn't 12V. Be safe.
Watch out for motor loads (like refrigerators) on a generator, they need way more watts to start than to run.
...tom
2014 WK2 Overland 5.9L
2007 WK Limited 5.7L
And some past Durangos
Red WK #19, Hemi #68.. I think..
Durango Owners Club DOTY 2011
"Must have been that yesterday was the day that I was born"
w1pf is offline
Two electrical questions 00' TJ Dickpalmer Audio, CB & Ham Radios, GPS, & Electrical 3 01-22-2012 09:30 PM
More Electrical - Got Questions..... JeepCrazy08 Audio, CB & Ham Radios, GPS, & Electrical 1 09-12-2011 01:47 AM
Probably a simple answer to a dumb questions but..... RRCP08JK Engines & Drivetrain 4 08-01-2009 10:16 PM
master welders please answer 2 questions teamoney Fabrication Shop 44 05-23-2009 05:47 PM
various piddly electrical questions. LoneJeeper Audio, CB & Ham Radios, GPS, & Electrical 6 11-19-2004 10:43 PM
