Snugging loose harness connectors? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Stereos, CB & Ham Radios, GPS, & Electrical. > Snugging loose harness connectors?
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 01-26-2013, 02:48 PM   #1
el scorcho
1990,4.2 YJ
I'm starting on the electric fan swap. I've got the Volvo 2 speed fan relay, Volvo fan and shroud and all the plugs. On one of the plugs that fits into the fan relay, the connectors IN the plug are loose and slide to the rear. With a slight tug, I'm sure they'll come out. Whatever sealant was there has severely deteriorated. How can I keep the connectors to the front of the plug and prevent them being pushed back? Should I just smear a little gasket maker up the back end of the plug and let it cure?
Thanks
el scorcho is offline   Reply With Quote Quick reply to this message
connector , harness , plug , wiring , wiring connector
