SirGCal - InSeat Speaker box Question. - JeepForum.com
post #1 of 3 Old 07-24-2006, 01:46 PM Thread Starter
Bhelliom
Bhelliom's Avatar
Hey SirGCal
I've been reading a lot about your box design and I'm planning on stealing it for my own use (hope you don't mind) I had a couple of questions for you.
I have two pioneer 10 inch shallow mount subs that I'd like to install in the box. On the other hand, I would like to make the seat as comfortable as possible (IE more padding)
Here are the specs for the speaker. Well, the one that are relevant anyways:
Recommended Enclosure 0.35 ~ 0.7 Cubic Feet
Dimensions 11-1/8" x 3-1/2"
Mounting Depth 3"
Having never built a box before, or umm... any stereo upgrade at all for that matter, I was wondering which enclosure dimensions I need to pay attention to? is one for a ported box and one for a sealed box? those stats are direct from the pioneer website.
The reason i'm asking is because for some stupid reason I can't seem to wrap my head around figuring out the internal volume of the inseat box for a 98 TJ if I make it shallower. How much thinner can I make the box to match the speaker requirements (mounting depth and internal volume) so that I can use as much padding as possible when putting the seat back together?
I've looked at your designs, and I believe I can take off 1.5 inches or so and still have the minimum internal volume right?
So confused. Also, do you have any other tips or tricks that you may have come up with since you made those designs? I'm going to be wiring it so that the seat is still removeable when I need to and placing the Amp in the console similar to another poster.
Any help would be much appreciated as I bought the jeep last week and the guy took out his stereo. I'm musicless at the moment.
Bhelliom is offline
post #2 of 3 Old 07-26-2006, 12:30 PM
SirGCal
RIP
SirGCal's Avatar
Originally Posted by Bhelliom
Hey SirGCal
Mounting Depth 3"
Those are sealed dimensions... Larger = smoother responce generally speaking... If you use the smaller box (one in the 2ktj writeup) you will be fine with a single 10". But don't use a pair. You could but the spike and droppoff would suffer. With the larger box, you could go either way depending on what sound your really after and how picky you are.
I have a volume calculator in the VB Programs section of my site you can use...
I'd have to think to answer that and honestly, right this second... I'm really not in the mood. But probably something like that... But also be aware that the bottom of the box can't change so you would have to take it off the top which would make the cutouts change for the top, back and side pieces including all the notch pieces...
I use deans connectors (see your local RC hobby shop) for easy speaker-wire disconnects (12 AWG rating and damn good connection).
Welcome to the Jeeping world...
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #3 of 3 Old 07-26-2006, 12:42 PM Thread Starter
Bhelliom
Bhelliom's Avatar
Thanks for the help and tips. I'll check out your volume calculator.
And I love the Jeep so far.
Bhelliom is offline
SirGCal inseat sub box -- complete *lots of pics* samger2 Audio, CB & Ham Radios, GPS, & Electrical 17 04-01-2007 08:59 AM
Inseat sub box question blorge Audio, CB & Ham Radios, GPS, & Electrical 11 09-04-2006 02:51 AM
Sirgcal: Stealth soundbar speaker project sgrim80 Audio, CB & Ham Radios, GPS, & Electrical 1 01-26-2006 07:03 PM
Question for Sirgcal etwolfe7 Audio, CB & Ham Radios, GPS, & Electrical 9 05-06-2005 11:06 AM
SIRGCAL or Speaker Guru's? sgrim80 Audio, CB & Ham Radios, GPS, & Electrical 3 02-16-2005 03:59 PM
