#1 | |||
Settings for MRD-M300
I'm about to wire and install my amp and wanted to know everyone's suggestions for the initial settings. This is my first sound system install, so I'm a complete noob.
Looking through the online manual, here's what I think I know: It looks like I adjust the input to set gain, I can find directions on SirGCal's site. My 8 inch subs are listed with a frequency response of 40 - 250 Hz. I think the highest I can set the low pass filter is 200 Hz, so should I just not touch it? I'll set the subsonic filter to 40 Hz. I'll also leave the Parametric EQ alone. I might turn the Bass Comp on later, but I think I'll have plenty of bass for my taste. I won't touch time corr, phase, amp set, or safe mode Save everything to memory when finished. Also- Unless I hear otherwise, I'll pick up a pair of 1/8" ring connectors with a 1/4" outer ring diameter to connect my power and ground to the amp terminals. I just hope I can find a ring that size that'll crimp onto a 4 gauge wire. ![]() Am I moving in the right direction? Any other suggestions? Thanks! Spyderbyte
#2 | ||
Anyone? I'd like to set this up today.
Thanks Spyderbyte
#3 | ||
Bump....
Spyderbyte
#4 |
I'd set you're lowpass to about 150Hz...you can play with it though to see what sounds best.
Above 150Hz and you're starting to get into the regular mid-woofer band and your subwoofer will overpower your other speakers. If you have an aftermarket headunit with built-in crossovers, set your highpass to about 150Hz (12dB slope) and if you're low pass on your amp is set to 150Hz (probably a 12 or 24dB cutoff slope), your system should sound pretty darn good. ~J
Formally JeepinTJ99 ... Go Anywhere: 2012 "Crush" Clearcoat JK Rubicon, loaded to the hilt || Thread Carve Time: 2009 "Racing Red" Buell 1125CR — 150 RWHP Will be missed: 1999 "Deep Amethyst" Pearlcoat TJ +3" on 33's |
#5 | ||
Okay thanks. My headunit doesn't have a high pass filter, but I don't think I'll mind if my speakers help out the bass a touch.
Other than that everything seems solid though? I'm hoping to bolt my amp in place and finish wiring tomorrow. Can't wait to be finished. Spyderbyte
#6 | ||
H*ll yeah! Everything's wired up (including a blue light up switch on the remote lead
) and it sounds great.One last question. I still don't understand how to set the gain. I tried following SirGCal's directions, 50 Hz tone, 3/4 volume, multimeter touched to the speaker outputs. Every single reading was 0 volts. I could hear the tone being played over my fill speakers (and subs when I had them connected), and my multimeter has otherwise been flawless. I also don't understand the adjustment for this amp. It seems like my only options are 0, -6, -12, and I think -18. I have my amp bolted sideways where my center console will go though, so I can't see the display too clearly. Can someone with this particular amp (SirGCal? ) give me a few tips? I have a Pioneer headunit with 2.2 volt RCAs and 2 8 inch subs wired to 300 watts x 2 ohms.Thanks! Spyderbyte
#7 | ||
Okay, I think I'm supposed to set the input to -12 dB to match my 2 volt RCAs, I have my subsonic set to 40 Hz, (could I go a touch lower even if it isn't in the sub's frequency range?), low pass filter to 160 Hz, and bass comp on.
Unless I hear I should change something, I'm going to replace my center console and it'll be a PITA to change settings. Thanks! Spyderbyte
#8 | ||
Bump again, does anyone know what exactly this adjusts? I'd like to be able to set my input to 0 db when I want to show off (I know it's not good for the subs, but it'd be short amounts of time). The best would be a smaller version of the RACC, essentially just the five buttons and display that I could mount behind the glove compartment or something.
Any ideas? Thanks again Spyderbyte
#9 | |
Ok, I'm here... Let's see...
Subsonic filter... If you were building a ported box, I'd say keep it at 30-40Hz, otherwise with a sealed box, 10-20Hz... It's not intended to stop the sound necessarily as much as it is to not waste amplifier power on non-audiable frequencies below the normal output. Sealed can go lower than ported without losing efficency below the tuned frequency so we give them a bit more room. Turn bass comp off for setup... Turn it back on for preference afterward (but recheck clipping light if you do...) The nice thing about the M300 is that it has a clipping light built into it! you don't have to do any guess work. Take some test tracks (like from my site) and setup the radio to play them at the precieved max volume (roughly 3/4 of the knob if you don't know the radio's clipping state) with all eq/loud/etc. features set to flat/off. Now if you have a sub level control on the head unit, set it to the middle (very useful for this amp since the amp is jump set instead of dial set). Now, loop the low frequency note so you can test the amp. with everything turned off on the amp (any enhancements), and just the crossovers (and subsonics) turned on, adjust the gain until the clipping light comes on then back it off one OR adjust the level control knob until the light goes out. I sometimes like to back it up and increase the level control knob to see if it will come on. If so, that gives you just a touch more flexability. Now, turn on the effects you want and double check the light.. If it comes on, adjust the level control again until the light goes out. There ya go. Insert favorite CD and jam... Pretty simple. No DMM required.
Sir G. Cal - 2k Sahara TJ Living and loving on borrowed time. Life with Multiple Sclerosis. My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more. Quote:
#10 | |||||||
Thanks for the help. I'd just like to clarify a few more things:
![]() Quote:
And is this the level control knob you're referring to? I don't think the amp itself has anything similar, but you also said you've never used the subwoofer level control. Quote:
Thanks again! Spyderbyte
#11 | ||||||
#12 | |||
Looks like I'm tearing apart my console again.
Here's what I'm planning to set:Subsonic filter: 15 Hz High pass filter: Currently 160 Hz, would 200 Hz be too overpowering? I'll probably turn on Bass Comp I won't touch time corr, phase, amp set, or safe mode Save everything to memory when finished. Unfortunately I'm still confused on gain. Quote:
Sorry about all my questions, as I said it's my first amp install. Thanks again Spyderbyte
#13 | |
The LPF, it's all dependent on what you have setup... 160 is probably about where you want it.. 200 might be ok but also might be boomy and annoying from too much low guitar...
As for the knob. the one for this amp is an optional external unit. The default one is the 4 settings you listed before.
#14 | |||
Thanks for all the help! Spyderbyte
#15 | ||
Well now I'm very confused. I did order the control knob and tore apart my console to install it today. The only problem is I absolutely cannot get the over light to come on. I set input to 0 db, turned the knob all the way up, and the headunit close to full volume as well. I even tried starting my Jeep a few times so it's running full voltage. My Jeep is shaking from the 50 Hz tone, but the light won't come on.
I also tried actual music, still no light. I have the display on voltage, does it matter? Everything still sounds clean, but I can't believe it's okay to run it like that. Also to double check, it should be a little red light just to the right of the numbers on the display, right? Thanks Spyderbyte
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
