RF power output fail new cobra CB any ideas? - JeepForum.com
post #1 of 7 Old 02-04-2011, 08:42 PM Thread Starter
madmilitia
i have a new cobra 29 lx le and at first i had a few issues with the SWR on the antenna being way to high.
the CB has a built in SWR meter. well i found that there was no insulation between the mount and the antenna.
the little plastic ring, so i fashoned up some insulation with electric tape and now the SWR is fine and the antenna passes the CB's checks but the RF power output fails.
i have no idae what that means and the maneul is no help.
any ideas ? thanks
RJC #600
colorado jeep club #269
Don't grammer cop me, if you can't understand what i'm trying to say it's you not me that needs to change.
madmilitia is offline
post #2 of 7 Old 02-04-2011, 10:51 PM
99WJNM
get another plastic ring. do you have the mic gain turned up (turned to the right)
99WJNM is offline
post #3 of 7 Old 02-05-2011, 12:35 AM Thread Starter
madmilitia
yeah i played with the mic gain and still no go
getting worried that this thing is broken
RJC #600
post #4 of 7 Old 02-05-2011, 01:28 AM Thread Starter
madmilitia
ok well i got the RF output thing to pass but then the antenna fails cause the SWR is at like 2.2-2.4 however if i hold the antena then it passes.
or if the antena is moveing back and forther. i'm pretty sure it's a grounding problem. i have a teraflex mounting kit coming in the mail should be here tomorrow hope that solves it.
RJC #600
post #5 of 7 Old 02-05-2011, 08:37 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Sounds like a bad ground on the antenna mount/mounting stud.
What antenna do you have.
Fiberglass antennas can loosen at the base and cause a bad connection.
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #6 of 7 Old 02-05-2011, 03:02 PM Thread Starter
madmilitia
it's a brand new firestick.
how ever the mounting brack i have is crap so i ordered a new one from teraflex.
only thing that is confuseing is the antennadoesn;t screw right in. i had to take a piece off the whip antenna taht i had on my jeep before and the fire stick screwed in to that and thenthat went in the mounting plate and my coax cable screwed in from the bottom.
RJC #600
post #7 of 7 Old 02-05-2011, 09:55 PM
Jon-joN
well if your getting a swr reading, that means your putting out power. but who knows how much. you really need to use an external meter when checking swr and power. if your antenna was being grounded and you keyed the mic, you very well could have burned up the final. thats something you should always check, make sure theres no continiuity between the antenna itself and the ground. but the radio may be fine, wait till you put on that new mount or fix the old one correctly before trying again.
Jon-joN is offline
Cobra 75 WX ST power m361 Audio, CB & Ham Radios, GPS, & Electrical 4 01-19-2011 12:52 PM
Power output of stock radio? DRM-2000 Audio, CB & Ham Radios, GPS, & Electrical 1 11-12-2008 03:31 PM
Cobra 75 install - where can I get power? imbezol Audio, CB & Ham Radios, GPS, & Electrical 14 09-04-2006 04:58 PM
(amp output) RMS power vs. dynamic power orangez Audio, CB & Ham Radios, GPS, & Electrical 3 07-18-2005 06:21 PM
Stock AM/FM cassette power output? Bob K Audio, CB & Ham Radios, GPS, & Electrical 1 11-09-2003 04:31 PM
