replacing dash speakers w/o folding windshield - JeepForum.com
post #1 of 6 Old 04-21-2014, 08:24 PM Thread Starter
Jeepyj311
Hey guys I have a '93 wrangler and had my jeep rhino lined. It was sprayed over the exterior hinges. I told the guy I didn't care because I would never fold down the windshield. Well now I want to replace the factory in dash speakers. Is there a way to do this without having to fold it down? I would appreciate all input and if anyone happens to have a pic or too I would be grateful.
Jeepyj311 is offline
post #2 of 6 Old 04-21-2014, 08:27 PM
fang_x
i belive on the yj's the dash panel must be removed to access the speakers, and my buddies jeep had screws that ran along the top of the dashboard. so youll probably have to pull it down, take a blade and cut the rhino liner off the hinges, or at least along the cracks and fold it down anyways. Its a jeep thing
heres some pics
http://www.jeepforum.com/forum/f12/y...cement-551707/
'98 TJ Manual -2.5" rcx long arm on 31
'99 Xj, Stock on 30"
'86 Monte Carlo 357 stroker. 450hp.
fang_x is offline
post #3 of 6 Old 04-21-2014, 09:44 PM
NonRubicon
Well, you can try and do it without pulling the dash, but it is going to be a beeotch. Pulling the e-brake assembly will give you a bit more room to work with on the driver's side. If you have big hands, forget about it.
The passenger side isn't bad for removal and install, it's the driver's side that is a Major PITA. I tried doing it without pulling the dash and almost got the driver's side installed but because the threads on the mounting studs weren't straight I couldn't get the speaker to align properly and set flush, so I ended up pulling the dash.
NonRubicon is offline
post #4 of 6 Old 04-22-2014, 07:52 AM
Indy
Indy's Avatar
Its been a long tome since i had a yj, i know i changed the speakers from behind without moving the windshield. If memory serves i only put 2 or 3 of the nuts on when i did, the 4th was a ***** and not important enough to deal with.
I'm the only gay eskimo.
Indy is offline
post #5 of 6 Old 05-01-2014, 11:50 AM
gily25
I used a centrapod with my YJ...it'll let you step up to a 5.25" speaker too.
iPhone app user; excuse typos...thanx.
gily25 is offline
post #6 of 6 Old 05-02-2014, 10:36 PM
Killswitch505
I really want to give this a try order it and post a review lol
http://www.quadratec.com/products/14133_2200.htm
Killswitch505 is offline
