Replacement subwoofer for factory console!
| Truck-Lite's New LED Headlamp Series | Ruffstuff Axle Simple Swap Kit! | Spartan Lockers FREE SHIPPING Excellent Prices |
#1 | |
Does anyone have experience with replacing the stock factory subwoofer with an aftermarket one? Did it make a difference?
Any brand recommendations that worked well? What size is that subwoofer anyway?
#2 |
i believe it is a 6" however you can fit an after market 8 with few modifications... but you will need a new amp, since the stock amp is running 1 ohm ( i believe) and no after market speakers are 1 ohm compatible...
FOR SALE Olympic Trunk for 03 TJ |
#3 |
thats not true red. a 2ohm DVC sub is 1ohm. there are a lot of 1ohm subs out there. if you upgrade the sub you will need to build a custom box inside the console. if you do a little reading you will find the thread that has the info you need. search is your friend. this is one of the most asked questions on here.
#4 |
oops.... i lied....
well, i tried..
#5 |
Thanks for the info guys. Can you help find that thread that you mentioned? I searched and couldn't find anything that really helped, must have missed it.
Thanks.... |
#6 | |
Yea, stock sub is 1-ohm (2-ohm DVC wired to 1-ohm), 6", supposed to be around 75W RMS but it's not in most cases... So you'll not find an after market equivalent without replacing the amp too. You can do a 6", 8" or even shoe-horn in a 10" I hear, into the console. Or you can do a lot more with an in-rear seat (see my site for more info) or behind-rear seat setup. There's endless posts of all these methods. As Mylt1 said, search is your friend if you want quick options.
Sir G. Cal - 2k Sahara TJ Living and loving on borrowed time. Life with Multiple Sclerosis. My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more. Quote:
#7 |
^that's what i thought.....
#8 |
didnt kicker used to make a 6" sub or were they just mid bass? what about the JL audio 6W0's?
edit, just looked at the JL's they only come in 4 or 8 ohm. oh well. but maybe one of them with a cheap little 75 or 90wrms amp would fill the bill? |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
