Replace head unit and retain steering wheel controls?
| Official Chassis Saver Rust Preventive Truck & Auto Un | TJ 5.25" Speaker Adapters - NalinMFG | SALE -- Yukon Gear Free Spin Hub Conversion Kit - Dana 30 |
#1 | |
Hi. I have a 2000 WJ (GCL) it has the Bose system with amp and the volume and other misc controls for the stereo built into the steering wheel.
I'd like to replace the stock deck that is in the vehicle, but I'd really like to keep using the steering wheel controls to control the new stereo head unit. Is this even possible? Is there a conversion kit or some way to wire the controls up to the new deck? Also, what about the stock amp - if I get a new deck will that stock amp still work with the 6 speakers in the truck? Thanks. Nocarrier
#2 |
Yes there is a way to keep your steering wheel controls. It is made by PAC and it is a steering wheel control adapter. PAC SWI-JACK Steering wheel control interface for Alpine, Clarion, JVC, and Kenwood at Crutchfield.com for Alpine, Clarion, JVC, and Kenwood headunits or this one for Pioneer, Jensen, and Sony PAC SWI-PS Steering wheel control interface for Pioneer, Jensen, and Sony at Crutchfield.com crutchfield is a bit high I got mine on ebay for about $40 but crutchfield will help you with setup and they also send you free wiring and trim pieces if you buy a headunit through them. Just make sure the headunit your looking at will work with steering wheel controls so that it can connect to the pac unit you buy. The pac unit just plugs in to the steering wheel control input on the new headunit you buy. You then wire the pac unit to keyed + power and ground and hook one wire I believe is red/yellow (double check me through its been awhile since I installed mine) under your steering column so that it can get the signal from the steering wheel controls. Then you program it to what steering wheel button controls what on the stereo. Sounds hard but the directions at pac's website make it pretty easy if you just go step by step. Works great in my 2001 WJ. You can keep the factory amp too. The wiring harness you will get to hook up your headunit will allow the factory amp to still function. But you may want to remove it and install a better amp if you plan to upgrade your speakers. The factory amp is pretty low on power. Have fun and good luck!
#3 |
yea talk about a pain in the ***. i just use the remote that came with my deck. the steering wheel buttons were kinda nice. I have way more functionality from my new deck, so im not going to worrie about some buttons on the steering wheel. my deck made that cheep infinity amp clip, to much power, so I bypassed it. the tweeters don't work, but i've got 2 way speakers in the doors. I read those tweets are pretty flimsy and go out anyway.
#4 | |
and regarding the tweets, mine are blown. disconnected them, now waiting for suitable replacements to come along, what have y'all used up there in the dash for that? PS.....bump lol definitely missed the date on this one |
#5 |
Well since you are asking. I replaced my stock front infinity system with a pair of infinity Kappa's 5 1/4" components and mounted the tweeter in the A pillar. On the TJ I located them at almost eye level. If they are too sharp for your liking they can be toned down at the crossover with I think a 3db cut. The speakers sound awesome.
Rich G. 2005 Wrangler 4.0, RE 3.5 Superflex kit w/ adj. front trac bar, RE Monotube shocks. Currie Adj. Rear Uppers,OR-FAB front bumper with Warn M8000 loaded with steel cable, AA SYE & T. Woods CV driveshaft, BFG 33x10.50x15, 165amp Heavy duty Alt. HID lighting, the rest are Clear lenses & LED, Shuriken AGM Battery, Pioneer Premier DEH-P7000BT, Memphis 16-MR1.1200, 2 Memphis Audio 15-MCP10D4, JL Audio 300/4v2, Infinity Perfect 5.1, MB Quart 6.5. Cobra 29LTD, Fire stick 5', vehicle security system. just4effect 10" single sub, enclosure and amp 4 sale. PM me if interested, local only |
#6 | |
although he was saying something like the dash speakers were just that, speakers and not tweeters. so i should probably find those 2 3/4 speakers instead of tweets and again, regarding the steering wheel buttons...maybe they can control somethinggg...anyone attempted? |
#7 |
A competent installer can make those buttons do damn near anything you might want. No, not Best Buy. A shop with talented installers can, though.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift 84 CJ7; frame off restoration in progress. The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice. |
#8 | |
The PAC stuff is nice; the hardest part is extending and running the wires for the IR emitter; the rest is simple. I used the PAC SWI-X unit, and extended the emitter wires, then mounted the emitter in the overhead console with some 5-minute epoxy into a small hole. The steering wheel buttons only have 2 wires that come out of the column. When you press a button it connects the 2 wires with a resistance, each button has a different resistance. You'd have to make a custom circuit that would read this resistance and then operate a specific output/low current relay or MOSFET. Then use that to drive a normal 12V relay. Sounds simple in theory, but it's not easy or in the capabilities of most shops. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
