removing the #%!*&@% dash - JeepForum.com
post #1 of 11 Old 11-10-2001, 06:16 PM Thread Starter
evilpsych
evilpsych's Avatar
Post removing the #%!*&@% dash
anyone wanna tell me how to remove my Freakin dash so i can remove the old speakers and install the new ones? it was a pain in the *** but i managed to get all those little nuts off and removed the passenger speaker.. the driver's side one is being a pain in the ***..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 11 Old 11-11-2001, 08:01 PM
9jeep0
9jeep0's Avatar
Post
Put your windshield down and take all the bolts off the top of the dash.I did mine that way and it was a lot easier.Make sure you oil the windshield hinges real well or you will bend the hinges.I bent mine and had to get new ones
Hope this helps
RED JEEP CLUB MEMBER #14
2006 TJ 4.0
1987 MJ 4.0
9jeep0 is offline
post #3 of 11 Old 11-12-2001, 05:10 AM
bonehead99
bonehead99's Avatar
Post
drop the e-brake and their should be enough room to slide it in. I did both without removing dash or droping windshield.
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #4 of 11 Old 11-12-2001, 10:26 PM
Willis91YJ
Post
Bonehead must have small hands. That e-brake stuff is craziness I tell ya! Take off the sport bar bolts at the windshield. Unbolt the windshield brackets above the speaks. Take out the bolts next to the speaks (the t-45 size) on each side. Flip down the windshield and then remove all the small screws along the top edge of the dash. Sounds compliocated but it only takes about 35 minutes if you have the right tools. Also If I were you when I pulled out the sport bar bolts, I replaced them with phillips head galvanized bolts from lowes. Makes it alot easier next time!
Willis
Black 91' YJ with fresh 4.0, Sitting on 31x11.5 Mickey Baja MTX's on 15x10 AR767, Borla Stainless cat-back, free flow cat, it seems like I keep breaking necessary parts just about the time I get enough money together for the fun stuff!!!
Willis91YJ is offline
post #5 of 11 Old 11-13-2001, 12:18 AM Thread Starter
evilpsych
evilpsych's Avatar
Post
well sounds like a plan.. was wondering why my frame was such a pain to bend down.. will lube it up first and remove all the screws etc.. oh.. i get to put the old ones back in because the new ones arent going to arrive in time before my t-day trip.. least my wrist will feel better..
A
post #6 of 11 Old 11-13-2001, 01:20 AM
eltj
Post
The easiest way to do those speakers is to take a deep socket 10mm and reach up behind the dash. The factory only puts them finger tight and with the lock washers that enough.
eltj is offline
post #7 of 11 Old 11-13-2001, 01:33 AM Thread Starter
evilpsych
evilpsych's Avatar
Post
finger tight my ***! i used a 10mm socket and my fingers.. they were waaaaaaay tighter than just finger tight.. took me bout 5 minutes each nut just to break them loose
A
post #8 of 11 Old 11-13-2001, 06:44 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Post
When I did the speakers on my YJ (I believe you also drive YJ), I found that a good sized prybar wedged between the tin and the body (once all the bolts were removed from the windshield triangle and the ones down the side of the body) was enough to squeeze my hand in and remove the nuts and then removed the speaker.
I had to do it a couple times as I needed to make a bracket to push my speaker away from the tin .. I choose the wrong ones .. had a large center piece that stuck out about 1/4". Argh!!!
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #9 of 11 Old 11-13-2001, 08:17 PM Thread Starter
evilpsych
evilpsych's Avatar
Post
heh.. anyway.. folded the windsheild down.. managed to crack it in the process from an earlier stone crack. went to gettin on the bolts with my T-27 torx bit, two came off easy as hell.. the other 3 were pretty much stuck.. tried oil etc.. finally had to cut notches into them using my dremel so i could use a flathead to break them loose and get them out.. made the reinstallation easy as pie.. when my good ones show up it'll be a piece of cake and i'll replace the windsheild after i get back from the roadtrip.. lot of gravel roads back there and i figure it'll get some other cracks in it..
A
post #10 of 11 Old 11-16-2001, 01:12 AM
Sarge37
Post
On 11/03 Evilphych wrote: "gee.. someone didnt spend a lot of time looking on the internet. the only hard one is the driver's side one.. and it's easy to get to just by removing the e-brake assembly.. the passenger side one isnt that hard either.. man.. you guys didnt even look in your haynes manuals did you? actually describes removing the factory speakers.."
"If It Aint Broke, Fix It Till It Is!!!!!"
05 TJ Rubicon, 4.0L, 6 Speed.
07 Ram 1500 Quad Cab
Sarge37 is offline
post #11 of 11 Old 11-16-2001, 01:15 AM Thread Starter
evilpsych
evilpsych's Avatar
Post
yeah yeah yeah.. i'm eatin crow now
i got them out didnt i without removing the dash..
just reinstalling was too damn hardso i had to take the dash off..
A
pics of painted dash??? anyone ever paint there dash? xj5399 Street Jeep Forum 21 02-20-2013 09:04 PM
Removing jeep dash board mnelson696 Audio, CB & Ham Radios, GPS, & Electrical 7 09-22-2008 07:42 PM
Removing paint from YJ dash sebastian22 General Jeep & Off-Road Equipment 2 06-27-2008 04:29 PM
Help removing center dash cover yellow_jeep Audio, CB & Ham Radios, GPS, & Electrical 4 04-02-2006 02:16 PM
