relay or no... please let me know - JeepForum.com
post #1 of 7 Old 09-25-2013, 06:22 PM Thread Starter
tylerp
So i was just wondering if you have to have a relay to run off road lights? I wouldnt think you would have to and what would happen if i didnt? If so how do i hook the relay up? thanks.
tylerp is offline
post #2 of 7 Old 09-25-2013, 06:52 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Fire bad, relay good. Use relay.
CJ7-Tim is offline
post #3 of 7 Old 09-27-2013, 03:35 PM
Vin
A relay will keep all the higher voltage in the engine bay and out of the cab. Can you run lights without? Yes. Are you better off with? Definitely. Less than a buck for security. Money well spent.
Vin is offline
post #4 of 7 Old 09-28-2013, 11:24 AM
Mainsail
2005 WK
You should always use a relay.
I'm running 900 watts of lighting on the grille of my M1009 and a relay isn't an option; I had to use a 12v solenoid to switch the power from the 24v bus bar.
Poor grammar is something up with which I shall not put.
Mainsail is online now
post #5 of 7 Old 09-28-2013, 12:03 PM
kingcat400
I think the word you are looking for is amp not volts. Its all 12v in a jeep.
kingcat400 is offline
post #6 of 7 Old 09-29-2013, 07:50 AM
biffgnar
biffgnar's Avatar
What kind of lights are they? LED setups can be done without relays. Most other types should have relays.
Romney in 2020!
biffgnar is online now
post #7 of 7 Old 10-05-2013, 04:44 PM
2jhanna
I generally use a 10 amp total draw as my threshold for relay or not. Most good quality switches can handle at least 15 amps easy.
This is for any assy, lights, amps, etc. more than 10, use relay.
Like said above, LED setups can draw as little as 3-4 amps.
jhanna
denton county, tx
2jhanna is offline
