Relay needed for 55w fog lights? Tap into existing relay? - JeepForum.com
post #1 of 6 Old 03-20-2010, 10:14 PM Thread Starter
SloppyJoseph
Hey guys. First off let me say that I thought I was good with wiring. Done so many car sound systems it's not funny. But this relay thing had got me thrown. I read the sticky and I think it said I dont need a relay for 55w lights.
I just wired in a set of KC fog lights on my bumper today. And my dad came over and had some old warn fog lights he's had in the garage since the late 90's. Anyway, I want to hook up both lights. Can I just get like a 30 amp rocker switch and call it a day?
Another option would be to splice them into the positive and negative wires on the kc system but im pretty sure it would overload it.
Im sure this is a pretty simple problem. Thanks for the help.
BTW, here are the lights he had. These are a little newer but same part# http://www.quadratec.com/products/97037_00X_PG.htm
SloppyJoseph is offline
post #2 of 6 Old 03-20-2010, 10:44 PM
ClimbStuff
I wouldn't worry about a relay for a single pair of 55w lights. You can go a long way w/o using a relay if you use the proper wire, fuses and switches. Hell there are 400 Farad capacitors out there that are strait wired... that's over 3000 amps at full draw.
ClimbStuff is offline
post #3 of 6 Old 03-21-2010, 09:02 AM
Slithering_Joe
I'd use a relay.
4.0L TJ
Slithering_Joe is offline
post #4 of 6 Old 03-21-2010, 10:10 AM
mylt1
mylt1's Avatar
everything gets a relay. its cheap insurance.
mylt1 is offline
post #5 of 6 Old 03-21-2010, 10:39 AM
SirGCal
RIP
SirGCal's Avatar
Every set of aftermarket lights HAS to have a relay... Anyone who even recommends not using one is a complete moron and should be ignored totally. The reason-why is very simple; It's very cheap insurance to avoid fire, provide a faster than humanly possible switching system which reduces arching (lowering fire chances and switch damage even more), and even offer you brighter light output as a bonus.
HOWEVER; if you are using the stock wiring (REPLACING the existing fog lights), there is already a relay in the line (two actually but one is for the purpose we need here). However the wiring itself in the stock setup can only handle ~ 55W of lighting.
I hope that clears it up.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #6 of 6 Old 03-21-2010, 11:27 AM Thread Starter
SloppyJoseph
^^ Thanks man, that clears it up. Relay it is.
Relay help needed RYANSTULC Audio, CB & Ham Radios, GPS, & Electrical 23 12-11-2008 06:23 PM
relay for kc lights racenkiwi Audio, CB & Ham Radios, GPS, & Electrical 6 08-11-2008 04:21 PM
Relay sockets, are they really needed??? rustywrangler Audio, CB & Ham Radios, GPS, & Electrical 4 04-09-2008 07:05 PM
Can you tie 6-55w rock lights in one relay? Justin'sJeep10 Audio, CB & Ham Radios, GPS, & Electrical 15 03-01-2006 01:00 PM
Relay needed? Festaman Audio, CB & Ham Radios, GPS, & Electrical 1 12-30-2004 08:40 AM
