Rear turn signal/brake problem - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Rear turn signal/brake problem
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!
Unread 06-08-2007, 05:42 PM   #1
hsif
I have a 98 ZJ and my left turn signal works fine but when I also apply the brake, it stops blinking, but when I let my foot off the brake it goes back to blinking perfectly. Does anyone know what could be wrong? I tried to replace both the brake light and turn signal lights, but same problem.
hsif is offline   Reply With Quote
Unread 06-08-2007, 08:28 PM   #2
RLD831
Could be the stalk on the steering wheel. My friend has the same problem and that's what he's doing to fix it. I'll update after he gets the switch.
Black 2001 Wrangler SE, stats in profile
RLD831 is offline   Reply With Quote
Unread 06-08-2007, 11:40 PM   #3
mylt1
could be a feed back in the tail light plug or even a bad ground. clean the contacts inside the bulb holder and check the groungs. if that doesnt fix it try a new socket.
mylt1 is offline   Reply With Quote
