rear ground for amp in Tj - JeepForum.com
post #1 of 6 Old 10-20-2002, 06:38 PM Thread Starter
bmcm161
I can not find a place with a small enough bolt to hook my amp in where can i find a place to ground it?
bmcm161 is offline
post #2 of 6 Old 10-20-2002, 07:24 PM
Drunc
Drunc's Avatar
Can't you ground it to the seat belts??
That's what I did...
Jeep: '88 YJ Laredo I6, Kenwood Deck, Amp and 6x9's, 10" pioneer sub, 2.5" Skyjacker Kit with a 1" body and new front shackles, 32" Mud Kings on 8" Desert Crawlers, CJ style replacement mirrors, ditched the trackbars and the endcaps
Drunc is offline
post #3 of 6 Old 10-20-2002, 07:58 PM
AllanAlxndr
Same for me... except I used the Seat mounting bracket
***What do I know, I just cause Problems***
*'90 Wrangler*
*4 Banger*
*6" of lift, (4" suspension, 2" body)*
*33" ATs on Outlaw II's*
*Pioneer DEH3500/CD deck*
*1800WATT Amp w/ Custom Box*
*2 - 8" Rockford Fosgate HEs*
*Cobra 18WXSTII w/ 4' Firestik Antenna*
Member of
AllanAlxndr is offline
post #4 of 6 Old 10-21-2002, 08:23 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Cool
What about grounding to the frame.
Drill hole in body, bushing, drill hole in frame, tap for proper thread size, clean metal and use tooth type lock washers, bang all done and there is no better ground.
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #5 of 6 Old 10-23-2002, 11:04 PM
Diggin'Taters
Diggin'Taters's Avatar
I uesd the seat belt too. Tested it and it is a good ground. I don't see a need for drilling a frame ground personally unless you are building a multi amp competition system or something. my .02
USAF Jeep Club Member #14
White Jeep Club Founder Member #1
REDNECK JEEP CLUB Member #1.1 and President!
Medical Cannabis Jeep club (I know I'm not the only member)
Diggin'Taters is offline
post #6 of 6 Old 10-24-2002, 04:53 AM
Scrambler82
1982 CJ8
bmcm161,
As Diggin'Taters says, the seat belt bolt could be a good ground.
Make sure what ever you use is some how connected to the frame ground.
Use a Volt/Ohm meter and check the continuity of the bolt to the frame.
Maybe run a wire from the bottom side of the seatbelt bolt to a frame connection or the battery ground.
Do it right the first time.
Scrambler82
CB HELP Where to Ground TJ Rear Bumper to? jermeyg Audio, CB & Ham Radios, GPS, & Electrical 6 01-18-2010 04:11 PM
Where to ground HU Brrcats Audio, CB & Ham Radios, GPS, & Electrical 9 12-17-2008 02:58 PM
Fog ground DBLJ Audio, CB & Ham Radios, GPS, & Electrical 2 10-02-2007 09:31 AM
Best Ground RARECJ8 Audio, CB & Ham Radios, GPS, & Electrical 9 03-07-2005 12:42 PM
CB Ground? Armory Audio, CB & Ham Radios, GPS, & Electrical 1 06-19-2003 11:36 AM
