reading a multimeter? - JeepForum.com
post #1 of 6 Old 09-16-2013, 11:58 AM Thread Starter
georged
I measured the IOD on my multimeter set on the 10 amp setting. The reading started at .3 and 30 minutes later it settled down to .01. When I switched over to the 200m or the 20m settings I didn't get a reading (also put the red lead in the proper plug). What is the .01 amp reading in mm?
georged is offline
post #2 of 6 Old 09-16-2013, 05:24 PM
Duh
Not sure exactly what you are asking. Amps uses the metric system. Amps, milliamps and microamps the most used. 1000 milliamps=1 amp, i assume you know the metric system.
Duh is offline
post #3 of 6 Old 09-17-2013, 04:27 AM Thread Starter
georged
Can you convert .03 amps to miliamps?
georged is offline
post #4 of 6 Old 09-17-2013, 05:11 AM
Duh
30 milliamps......
Duh is offline
post #5 of 6 Old 09-17-2013, 04:11 PM
freeskier93
What are you measuring (I don't know what IOD is)?
freeskier93 is offline
post #6 of 6 Old 09-17-2013, 05:45 PM
Duh
Iod is chryslers shipping fuse-ship them with no fuse to limit draw on battery. All the unnecessary stuff feeds partially though there. They now do it with software instead.
Duh is offline
