#1 | |
Radio Dead and Dome Lights Dead
Hey guess Ive had an alpine cd player in my car for like 6 months and it has worked fine with the two front speakers well I decided to install a sub and amp. I wired everything up but the ground were I grounded it was iffy. I had the hood open so that light was on and the dome lights were on. The switch was on accessory (you know like when the fan will start) and I turned on the radio and it played though the front speakers and the amp had power only the sub wouldn't play so I got to fooling around with the sub control on the cd deck and nothing would happen I turned it up a couple notches and everything just went dead. All the dome light and the radio dont work. Everything elese still works fine. I burnt one bulb in the dome lights and I replaced it and nothing wouldn't work. I also changed and checked all the fuses under the dash and under the hood and suggestions
Email me with questions menace59@aol.com Thanks JIM ![]()
#2 |
Broke Bogger
Well the same thing happened to me, but it was just a fuse. Check again under the hood, there is a 30 amp (small green) fuse that controls the lights and radio.
Matt __________________ 97 XJ - Black Sport, 4.0L AW4, D30 and 8.25 6" Skyjacker/RE, 33x13.5 Swamper LTB Cracked Frame, good for steering!!! MY XJ PICS |
#3 |
yea I have a 94 YJ though I didn't find a small green fuse. But under the dash I think it says radio relay or something and its not in there but it worked with out it before. Also under the hood there is a fuse called OID or something like that I dont know what it stands for. The guy at the stereo place in town said that the allumination with the radio is tied into the dome lights or something like that Didn't really understand what he said. so
reply back please JIM |
#4 | |
I'm not sure what he was talking about. There is an illumination wire on many units (Alpine included) that dims the head unit lights when the headlights are on... but...
It sounds like a fuse or relay went bad. I'd get a simple voltage meter and start tracing from the battery back into the system until I found the break.
Sir G. Cal - 2k Sahara TJ Living and loving on borrowed time. Life with Multiple Sclerosis. My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more. Quote:
#5 |
Thanks Any more suggestions I will probably have to do that but if it is the cd player I still have warranty on it so Im ok in that situation.
Thanks Everyone The thing that puzzles me the most is everything else works but just the dome lights and the radio JIM ![]() |
#6 |
Found the Problem
I found the problem today the actual power wire in the harness is shorted out. Anybody got a clue why it shorted out and Howcan i get power to the radio with out running from the battery cause right now i have it hooked into the illumination and everytime the lights get shut off before the car or the car shuts off the radio looses its memory !
Thanks Guys, Keep Jeep'n JIM ![]() |
#7 |
There should be a constant 12V+ wire in your harness. It is always powered and should be hooked up to the 12V+ memory wire on your HU. Check in your head unit manual for which wire it is. Sounds like you hooked the illumination wire up to this by mistake. In addition, there will be a switched 12V+ wire and the illumination. Make sure all three of these are going to the right place (they can be easy to confuse) and you will be all set.
Good Luck, Peter
1996 XJ Sport 4.0L I6 HO; AW4; NP242; D30/D35; 3" Homebrew BB; 31" x 10.5" BFG A/T Six Harbor Freight Lights (el cheapo) GREEN JEEP CLUB MEMBER #74 |
#8 | ||
I actually hook it up to the illumanation on purpose because the 12 volt in the harness is dead. Any got any ideas can i run a new power constant 12 volt if so tell me how could you please. Cause when its hooked up the way i do it looses the memory everytime. THanks JIM |
#9 | ||
Now run the wire from the radio, through the gromet on the drivers side firewall, then around the engine (in some wireloom preferred) with the other wires using zip-ties to secure it. Leave a little slack in the wire for extra room (you never know when you wish for 1" more wire...) Once you get around the computer to the engine, put on the fuse holder and fuse. Then disconnect the negative battery terminal. (the negative terminal should ALWAYS be the first terminal off and the last terminal on.) Once the negative is off, disconnect the positive terminal (some people also use the mounting plate just inside the fuse panel located next to the battery in newer vehicles in the engine bay for easy connection. This is connected directly to the battery with 4 AWG wire which is plenty.) Connect the new power wire and reconnect the positive battery terminal, followed by the negative battery terminal. Assuming your ground is ok, your now good to go and better off than running through the factory harness anyhow...
#10 | |
I dont understand how to hook it in. Can I hook into the fuse panel inside the car and how? Just put the wire in the hole and put a fuse on top of it. I really dont understand sorry Im dumb. Help please ! |
#11 | ||
Connect the radio-end first. Then the battery end. To connect the battery end, attach a ring connector to the end of the wire large enough to attach to the battery terminal. Disconnect the negative battery terminal first!!!! Then you can disconnect the positive terminal and attach the new wire. Reattach the positive terminal then the negative terminal. You should now be good to go. ![]() If any of this still seems vague, you might want to go to an electronics installer shop. They'd do this simple task for probably just a few dollars. It should take no more than 15-30 minutes for an experienced installer.
#12 |
With it directly connected to the battery will it drain it. I also have a power wire for my amp (subwoofer) hook to the amp with the affect it also !
One more thing since it will be getting constant power the memory wont be lost will it ? Thanks, JIM PS I completly understand now In the firewall is where i ran my power wire for my amp too ! is that ok ? Thanks again Last edited by bigjeep310; 03-15-2004 at 02:07 PM.. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
