radio cuts in and out - JeepForum.com
post #1 of 5 Old 05-13-2008, 08:22 AM Thread Starter
genakab
this isn't in a jeep, but my girlfriend's radio in her car turns on and off randomly, not corresponding to bumps or movement. i checked the fuse, and it was fine, so i took out the head unit and tested the ground and the two +12 wires with a light bulb, and they have continuous current that doesn't turn on or off. my question is could there be another loose connection somewhere that would cause the radio to shut completely off (including the clock), or are these three wires the only ones that could affect that (besides a broken head unit)? any ideas?
genakab is offline
post #2 of 5 Old 05-13-2008, 08:35 AM
SirGCal
SirGCal's Avatar
Even though you tested power. Doesn't mean one doesn't have a lose connection. Make sure they are all solid and in strong. There are two 12V wires (one constant, one switched) and a ground. If any one of those are lose, this will happen.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #3 of 5 Old 05-13-2008, 01:34 PM Thread Starter
genakab
so if those three wires end up being solid and working, then its probably the head unit? im going to try to find a spare head unit laying around and plug it in and see if it works. i just dont want to get one and have it do the same thing.
thanks!
genakab is offline
post #4 of 5 Old 05-13-2008, 02:22 PM
SirGCal
SirGCal's Avatar
If a new one did the same thing, it can only be something with the wires... But if you really wana test it, you could run a new fused wire to the battery, one to ground and use a relay to trigger the switched wire. Then you'd be sure it's not the wires (unless it's the one your triggering the relay with).
SirGCal is offline
post #5 of 5 Old 05-14-2008, 04:58 AM
EB23
If it has a removable faceplate, check the contacts for corrosion and clean them with some electronic cleaner.
eb
My Jeep memorial site (Jeep sold March 2010): http://razmear.us/jeep
EB23 is offline
04 rubicon radio cuts out still Alex74012 Audio, CB & Ham Radios, GPS, & Electrical 2 01-14-2010 10:16 AM
radio cuts out 617HC Audio, CB & Ham Radios, GPS, & Electrical 12 03-12-2009 07:50 AM
Radio Cuts In and Out... thejones101 Audio, CB & Ham Radios, GPS, & Electrical 0 11-09-2008 03:27 PM
Help!! Radio cuts out. Patriot Blue Audio, CB & Ham Radios, GPS, & Electrical 0 05-06-2007 12:12 AM
Cuts off SuperStreetJeep Audio, CB & Ham Radios, GPS, & Electrical 1 06-24-2006 01:23 AM
