Radio Compatibility...Grand Cherokee - JeepForum.com
post #1 of 8 Old 02-07-2005, 01:13 PM Thread Starter
jj33low
I am looking to replace my in-dash cd/cassette radio in my 1996 Grand Cherokee. What other oem radios are compatible? Would an '05 in-dash unit work? Does anyone know?
'96 Grand Cherokee Laredo 4x4- daily driver
'04 Subaru WRX (heavily modded)- sports car
jj33low is offline
post #2 of 8 Old 02-07-2005, 02:14 PM
SS01XJ
I can't answer your question directly, but in at least one case I know of, Jeep must get a lot of mileage from their radio designs. My brother has a '95 Dodge Spirit that has the same radio in it that my '01 XJ has. I suspect a wide range of models and years would work.
HTH...........Stan
SS01XJ is offline
post #3 of 8 Old 02-07-2005, 02:35 PM
99TJSport
99TJSport's Avatar
For sure I know 96-98 Grand Cherokees, 97-02 Wranglers, 97-01 Cherokees, 94-00(??) Dakotas and 94-01 Dodge Rams will interchange.
Jeff
08 Rubicon Unlimited, 2.5TF Lift, 285/70/17 BFG KM2s, lots of skids, MyGig, and both sets of doors/tops.
Parrothead Jeepers Union #24
99TJSport is offline
post #4 of 8 Old 02-07-2005, 05:24 PM
C2U5H
C2U5H's Avatar
if you're goin to swap, get an aftermarket one...
just go to crutchfield.com, go to "what fits my car?" on the left menu bar, and go find one that you like and is in your price range! have fun!
~J
2012 Crush JK Rubicon on 2.5" and 37s
- see sidebar
C2U5H is offline
post #5 of 8 Old 02-08-2005, 01:45 PM Thread Starter
jj33low
Thanks for the replies. I am well aware of aftermarket headunits. I once had a demo car sponsored by Polk Momo with a full competition system in it.
For the Jeep, I want to stick with oem for the oem look and would prefer an newer unit, preferably an '05 unit (w/ 6 disk indash). I need to know if they will work and if not what it will take to get them to work.
jj33low is offline
post #6 of 8 Old 02-09-2005, 06:08 AM
99TJSport
99TJSport's Avatar
See my above post The 05 units will NOT fit due to changes in the face and the mounting brackets.
Jeff
post #7 of 8 Old 02-09-2005, 12:56 PM Thread Starter
jj33low
Couldn't I just modify the brackets? As lons as the electrical hook ups are the same, I could probably make it work. They are both 1.5 din aren't they?
jj33low is offline
post #8 of 8 Old 02-10-2005, 06:36 AM
99TJSport
99TJSport's Avatar
Mounting is actual molded into the platic face of the radio, so there is no way to change it out. As for wiring, your truck will have 2 7 pin plugs, while the new Jeeps have a 1 pieces like 21(?) pin plug. Chrysler does make an adapter harness for them so it's possible, but I really think the mounting will be the biggest problem for you. There's just no easy way to change it.
Jeff
1994 grand cherokee factory radio and amp problem g-ac-15 Audio, CB & Ham Radios, GPS, & Electrical 2 08-19-2008 05:37 PM
Installing aftermarket radio in Grand Cherokee? absentiabanish Audio, CB & Ham Radios, GPS, & Electrical 5 03-11-2007 09:33 AM
REJ Radio-Navigation for Grand Cherokee 2005 Wave Audio, CB & Ham Radios, GPS, & Electrical 0 05-12-2005 07:58 AM
2002 Grand Cherokee Radio Mute circuit? BIM Audio, CB & Ham Radios, GPS, & Electrical 3 12-03-2004 10:05 AM
Can a 2002 Grand Cherokee Radio fit a 1996 Grand Cherokee limited? banzayworld Audio, CB & Ham Radios, GPS, & Electrical 4 10-20-2002 10:25 PM
