Quick question about relay to light distance - JeepForum.com
post #1 of 6 Old 01-20-2013, 01:48 PM Thread Starter
andygio71
I'm looking to install some auxiliary reverse lights, and am not sure where to put the relay. I seem to remember reading that the relay shouldn't be more than 6 feet from the farthest light, but can't find that anywhere now. I would prefer to have it up front because i have a Bussmann relay/fuse box next to my battery up front because it would be much easier to service. Would that distance to the rear bumper be a problem?
andygio71 is offline
post #2 of 6 Old 01-20-2013, 02:15 PM
Icarus
Should be fine, make sure to use the correct wire for the draw of the lights though and fuse it close to the battery.
Ϣr
Icarus is online now
post #3 of 6 Old 01-20-2013, 02:34 PM Thread Starter
andygio71
Thanks, that's what i was hoping to hear
post #4 of 6 Old 01-21-2013, 01:49 PM
mylt1
mylt1's Avatar
relay location isnt important but fuse location is, if you are wiring direct to the battery.
mylt1 is offline
post #5 of 6 Old 01-21-2013, 08:17 PM
JPNinPA
Sounds like you have a nice setup . I ended up putting the relay inside the driver side tail light. It was tight. I spliced into the wiring just outside the housing. The only wire run back fram the fusebox was a power wire for the relay.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #6 of 6 Old 10-18-2013, 07:10 PM
gcjeeping
gcjeeping's Avatar
Op your inbox is full...
_____________
gcjeeping is offline
