Push button start - JeepForum.com
post #1 of 2 Old 04-30-2014, 04:09 PM Thread Starter
Keifer
Push button start
So, I have a 1986 CJ7 that I'm trying to install a push button start in. I have it all hooked up except for the brake wires. Right now, when I push the button it'll go to acc mode and run mode, but I can't get it to actually start. I believe I wired the ignition harness correctly, so I think it's the brake wires that are holding me back. It says the brake needs to be pushed to start it and I was wondering if there is a way to bypass the brake wires?
Thanks!
Keifer is offline
post #2 of 2 Old 05-01-2014, 09:24 AM
strvger01
1966 CJ5
i just left the original ignition switch to use the key for all the accs and wired the push button directly to the starter. once i knew the button would start it (with the key turned to the 'on' position), i just cut the starter wire off the ignition switch. my jeep was older, but it worked.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline
