power windows inop - JeepForum.com
post #1 of 5 Old 08-24-2013, 04:37 AM Thread Starter
4literdieter
So my windows don't work on my 2000 Cherokee from any door even though my mirrors and locks do.its not the main switch cause i tried a working one and got the same results. The manual says there's a circuit breaker for the windows by the fuses. however, i see no such breakers. if anyone had an electrical diagram of the window switch that would help me drastically.
4literdieter is offline
post #2 of 5 Old 08-24-2013, 08:48 AM
gily25
You could have a microhole in the tank...you should take it for a submersion test if you can't find the break.
Power window relays are usually under the good and the motor fuses in the inside fuse box. Is it all windows? If it's just one, the wiring at the door jamb may be cracked.
iPhone app user; excuse typos...thanx.
gily25 is offline
post #3 of 5 Old 08-24-2013, 12:52 PM
Holder350
1995 XJ Cherokee
Does this jeep happen to have a year and model? It should help drastically in giving you specific advice.
Sent from my phone
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #4 of 5 Old 08-25-2013, 02:25 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
It is extremely common for XJ Cherokees to have wiring issues in the drivers door. Inspect the drivers door wire harness for chafed/melted insulation, broken or cut wires, and failed wire splices.
If the child safety lockout switch has failed, none of the windows will work from their own control, they will only work from the drivers door master switch.
CJ7-Tim is offline
post #5 of 5 Old 08-25-2013, 03:37 PM
Holder350
1995 XJ Cherokee
Here are the wiring diagrams for the power window circuit.
