Power Source to Tap in the Engine Bay?
| Spartan Lockers FREE SHIPPING Excellent Prices | Black Magic Brakes - 5% Off, No Minimum Purchase Required | DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- |
#1 | |
I've had my KC fog lights wired up for a while now and last month they stopped working, I had originally just taken a copper wire and made a small loop and put it on the batter under the main power. It stopped working because the copper fried off, is there a better way to tap into the battery through another wire or some other kind of wire I can use? Thank you.
#2 |
perhaps a crimped on eyelet on the battery terminal bolt
HISWhite 99 XJ Sport
4" RC/ProComp lift, Serious long arms, 33" Cooper STTs, Soft 8s, 4.56s, Aussie locked D30, LSD 8.25, IRO adj track bar and HD Tie Rod, IRO HnT SYE, home made discos, recovery and sliders HERSBlack 08 JK Unlimited X, Stock for now, 2 1/2" and 33's to come |
#3 |
You think I'll be able to find one big enough?
#4 |
Yep. They do.
#5 |
If by "fried", you mean corroded, this is because the battery tends to be corrosive. If "fried" means it burned, this is because you need some kind of current-limiting device (like a fuse) to prevent the battery's full current from flowing through this wire in the event of a short or overload.
Follow the battery cable to its other end (probably the starter or a "solenoid") and connect a fusible link to that terminal. Then splice you wire to the other end of the fusible link. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
