Power Distribution Center - JeepForum.com
post #1 of 5 Old 07-21-2007, 09:05 PM Thread Starter
Bricolage
2003 WJ
Zj Power Distribution Center
I am hoping you guys can help me with this. Is there a way to remove a power distribution center from a 1993 Jeep Grand Cherokee Laredo I6?
When I was looking at my air conditioner wiring, I checked the relay in the PDC for the A/C and found that it was not engaging. After cross checking with the fuel pump relay (an identical relay), I discovered that the socket for the relay in the PDC had no electrical power. I want to see if there is a bad connection in the PDC, how can I do this?
Thank you,
Tom
Bricolage is offline
post #2 of 5 Old 07-22-2007, 09:33 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
I do not know what the Jeep "PDC" actually looks like but I would thing you could just probe it with a multimeter and find out what you want.
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #3 of 5 Old 07-22-2007, 09:37 AM Thread Starter
Bricolage
2003 WJ
I was able to find where the failure was with the multimeter--the failure exists where the power should be coming from. So unless there is some sort of massive failure elsewhere, I am tempted to open up the power distribution center and look around.
post #4 of 5 Old 07-23-2007, 07:05 AM
Scrambler82
1982 CJ8
I wish I could help you more, I am not only new to Jeep but mine is anything but an original Jeep.
This will at least get you bumped up.
Scrambler82
post #5 of 5 Old 07-24-2007, 08:47 PM Thread Starter
Bricolage
2003 WJ
I was able to accomplish my goal. For reference:
I took two screw drivers to pry the clips on the side. Then I had an assistant pull on the PDC box until it popped out of its metal seating. The bottom had a couple of clips to pull on to remove the bottom and I was able to look at all the PDC wiring. Although the chance of the PDC or any of its wiring being defective is 1/1000000000000, it is nice to have the re-assurance.
power distribution conundrum masterwacker Audio, CB & Ham Radios, GPS, & Electrical 6 11-24-2009 02:44 PM
relay/power distribution box Holder350 Audio, CB & Ham Radios, GPS, & Electrical 6 09-12-2009 05:26 PM
How do I make a power distribution block bobmcc81 Audio, CB & Ham Radios, GPS, & Electrical 2 08-10-2009 02:59 PM
Power distribution center XXRider Audio, CB & Ham Radios, GPS, & Electrical 5 12-08-2008 11:26 PM
AUX power distribution block BostonJosh19 Audio, CB & Ham Radios, GPS, & Electrical 20 03-07-2007 02:52 PM
