Power cuts out on stereo - JeepForum.com
post #1 of 6 Old 05-29-2013, 07:40 PM Thread Starter
ton12loc
I have a 92yj. I had a jvc head unit in there for years and everything was fine. Then I wasn't getting sound to the speakers here and there. I figured it was the head unit going up. I bought another and installed and everything seemed fine. Now here and there the power just cuts out to the unit. It might come back on right away or in a few minutes. There really is no consistency. When I got the new stereo I got a new wire harness also and connections seems fine. Any ideas?
ton12loc is offline
post #2 of 6 Old 05-30-2013, 11:18 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
I would look for a wiring issue, either power wires, or speaker wires. Most head units will trip an internal circuit breaker if there is a speaker wiring short circuit.
CJ7-Tim is offline
post #3 of 6 Old 05-31-2013, 07:44 AM
gily25
Sounds like a bad ground. Check and make sure the connection is secure. Also make sure the radio is secure in the dash, sometimes they will slide in the metal sleeve and manipulate the wiring for a minute to fail then slide back into place and everything is normal.
iPhone app user; excuse typos...thanx.
gily25 is offline
post #4 of 6 Old 06-01-2013, 09:19 AM
GilaMtnJeep
GilaMtnJeep's Avatar
Don't know how the YJ is set up but in my 03 TJ it was doing the same thing. Turned out to be the ignition cylinder. The key would back out while driving and the radio would go off. I found out I can start mine and pull the key right out. Once I figured it out I just lived with it. I just push the key back in and it comes right back on.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #5 of 6 Old 06-03-2013, 03:06 PM
Miller97
x2, the best defect of the 03 TJ. Its hard to look cool rolling down the street with loud music and then you hit a pot hole.
2003 Silver TJ Sport, BF Goodrich 30" A/T KO's. RIP 11/2013.|| '03 Gold Wrangler X. Project "Golden Eagle"
Miller97 is offline
post #6 of 6 Old 06-04-2013, 11:05 AM
gily25
If it's that bad you may want to have a new key cut off the VIN # or think about having less key chain crap hanging off your key.
gily25 is offline
