points to electronic ignition - JeepForum.com
post #1 of 2 Old 09-26-2004, 12:47 PM Thread Starter
jstltreat
Can you use electronic plug wires on a point ignition system? Are their a difference in wires? My cj7 has a 1974 amc 360 and it misses bad especially at speed, and I am trying to figure out what the problem is. I have checked everything else, then notice the wires are for electronic ignition. Could this possibly be my problem. Thanks alot. Steve
jstltreat is offline
post #2 of 2 Old 09-26-2004, 02:23 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Some electronic ignitions use points to trigger them, that's probably how yours is set up. One good mod is to replace the points with a drop-in replacement that has a sealed switch that duplicates what the points did... much more reliable than mechanical points are.
Sounds like it's time to take it to a shop that has an analyzer so you can see what each plug is doing. I assume you checked your points, set the dwell and set the timing? All plugs in good shape and the right plugs? Not Bosch plugs I hope.
Jerry Bransford is online now
Electronic Speedo Correction Mulie Technical Articles & Write-Ups 18 10-20-2013 06:56 PM
Electronic Problems Pudlee01 Audio, CB & Ham Radios, GPS, & Electrical 1 03-24-2009 09:45 AM
Dana 18 Electronic Speedo LuvTopless General Jeep & Off-Road Equipment 0 10-03-2008 12:19 PM
electronic / moisture problem TJ on the Rocks Audio, CB & Ham Radios, GPS, & Electrical 5 04-20-2007 03:52 PM
TFI or DUI upgrade from a points ignition? Brock Engines & Drivetrain 5 06-25-2003 12:19 PM
