Please help...electrical issue - JeepForum.com
post #1 of 9 Old 07-23-2010, 03:22 AM Thread Starter
KATHYSCHMIDT
Thanks in advance for everyone's help. I have a 2001 Jeep Wrangler. I took it to work one day and went to leave... it would not start.... my brother thought it was the ignition switch so he ordered one and replaced it...He replaced the ignition lock cylinder... still no start.... then we replaced the nutral safty switch... he has checked all fuses... replaced the ignition relay... battery is good... and the starter was checked and is good... what else could it be? gauges act screwy and radio does not work.
KATHYSCHMIDT is offline
post #2 of 9 Old 07-23-2010, 06:16 AM
Richd1963
Richd1963's Avatar
Have you tried to give it a jump start? Are the battery cables in good condition? I am leaning towards the battery or connections...... What does it do? Will it crank? weak crank? What exactly happens when ya turn the switch.
Rich G. 2005 Wrangler 4.0 6-Speed.
just4effect 10" single sub, enclosure and amp 4 sale. PM me if interested, local only
Richd1963 is offline
post #3 of 9 Old 07-23-2010, 06:26 AM
Freelanc
if it doesn't try to crank, and the battery and starter are both good, then it's got to be the connections to the battery. mine didn't start once because the ground wire for the starter had broken.
Freelanc is offline
post #4 of 9 Old 07-23-2010, 08:45 AM
SirGCal
SirGCal's Avatar
How do you know the battery is good? Did autozone or someplace 'test' it for you? If so it is very possibly still bad. I don't think they ever successfully tested a known bad battery I had when I went in for a proper replacement. They always test em and they always say it's fine... If it has not been replaced in a few years; REPLACE IT. Then you KNOW it's good for sure and can move on to other items. It would be overdue for replacement anyhow.
The next most likely is simply the cables. Check all of them or even just replace the main runs (alt, bat, ground, starter). And what about the starter solenoid... Can you measure 12V when it is trying to crank? Is it getting the signal? If so, the solenoid is still bad. (or your engine is completely seized).
There really isn't much to fail in this area... Start with simple and common (and cheap) and work up from there... Or take it into a specialist to do it all for ya...
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #5 of 9 Old 07-23-2010, 03:12 PM Thread Starter
KATHYSCHMIDT
Thanks for everyone's reply
The Battery is good... I not only had it checked but have tried a new battery just to make sure... It had brand new battery cables intalled. The starter spins when you jump the termanls directly to the starter. The engine is not seized it will jump when you give the starter power. It clicks once when you turn the key.
post #6 of 9 Old 07-23-2010, 03:40 PM
SirGCal
SirGCal's Avatar
Solenoid.. Pretty simple...
SirGCal is offline
post #7 of 9 Old 07-23-2010, 04:10 PM Thread Starter
KATHYSCHMIDT
Which solenoid are you talking about?
post #8 of 9 Old 07-23-2010, 05:20 PM
SirGCal
SirGCal's Avatar
You jump the terminals on the starter which short it out, bypassing the starter solenoid. And it works. But the key doesn't. As long as the solenoid input is showing 12V, then the solenoid (or starter relay, I think it's actually just a relay on the 01... but I'm not near my FSM...) simply isn't triggering. Thankfully though that's a cheap fix...(likely <$20)
That's what it sounds like to me anyhow. It might even be as simple as the fuse feeding the relay.
SirGCal is offline
post #9 of 9 Old 07-23-2010, 05:46 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Yep the order of things is the ignition switch which powers the starter relay (inside the Power Distribution Center on the passenger-side fenderwell in the engine compartment), which powers the starter solenoid which provides power to the starter motor itself.
The ignition switch, starter relay, and starter solenoid are all nothing more than simple electrical on-off switches, each one getting bigger to handle more amperes as they get closer to the starter motor.
Getting
Jerry Bransford is offline
Strange starting system electrical issue sprowley Audio, CB & Ham Radios, GPS, & Electrical 6 05-04-2010 02:10 PM
wierd electrical issue. need help asap briggs2 Audio, CB & Ham Radios, GPS, & Electrical 8 12-15-2009 11:16 PM
Odd? Electrical Issue? Johnny5isAlive Audio, CB & Ham Radios, GPS, & Electrical 3 04-17-2007 01:40 PM
Wierd electrical issue neZZr Audio, CB & Ham Radios, GPS, & Electrical 1 11-27-2005 12:15 PM
