Old midland CB - JeepForum.com
post #1 of 13 Old 07-23-2007, 02:48 PM Thread Starter
88blaster
Old midland CB
It is a model 77-882, I got it for free from my grandpa for free. I put it in my jeep in place of my cobra 19. I sold that one for $20 cause I need money. The midland works really good except when I talk the ant warning light comes on, I assume that it has something to do with the SWR? Does this radio have a feature that protects it from burning out of the SWR is to high? It is a 1977 model. Also it has a nob labled Delta Tune with - 0 and + what does this nob do? what does the anl switch do? and what does the NB switch do? Sorry I am so cluless, my grandpa doesn't remember anything about it.
Eagle Scout Club Member #2
Silver Cherokee
88blaster is offline
post #2 of 13 Old 07-23-2007, 05:12 PM
97_tj
try this info it sounds loke a good radio hope this helps there is alot of info in the google search
http://home.ptd.net/~n3cvj/77-882.htm
some more info
Click to View Search Results for Google (Search Results) Google (Search Results)
97_tj is offline
post #3 of 13 Old 07-23-2007, 05:54 PM Thread Starter
88blaster
Cool, I had done the google search but that first article was extreamly helpful.
Silver Cherokee
post #4 of 13 Old 07-23-2007, 07:25 PM
SpeedyCat3
Survivor
SpeedyCat3's Avatar
Do not know about the ant warning light, but the delta tune is used to tune in incoming signals that might be slightly off frequency.
Will try to find out about the warning light.
Cheers.
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
SpeedyCat3 is offline
post #5 of 13 Old 07-23-2007, 10:13 PM Thread Starter
88blaster
Cheers.
Some one else said it will come on when swr comes above 3:1 It is weird though because it is off when olding the transmit button but when you actually talk it come on and gets brighter the louder you talk.
Silver Cherokee
post #6 of 13 Old 07-23-2007, 11:31 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That light is measuring the reflected power, and that is what a high SWR does, a mistuned antenna with a high SWR reflects power back towards the transmitter instead of radiating it. So since a CB transmits with a bit more power (it's not theoretically supposed to but most do) when you're talking, that's why the antenna light lights up more when you're talking since the antenna is reflecting back more power while you are talking.
Get the antenna tuned or find out what's wrong with it. An improperly installed mount is the usual cause of abnormally high SWR, and that problem is usually caused by the mount not getting a good enough electrical ground connect. Like being bolted to a painted surface instead of bare metal after the paint was ground away.
Jerry Bransford is online now
post #7 of 13 Old 07-24-2007, 06:25 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Old elctronics dry out, especially if not used.
Check the SWR, if the SWR Meter has a Power Meter too, check the power out just for grins.
As Jerry stated the power will actually increase when you talk and the older CBs did it more than the newer ones.
You may not be able to stop the light from coming on.
If the SWR checks out OK and the CB is working OK for you, leave it as is and live with the light.
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #8 of 13 Old 07-24-2007, 11:46 AM Thread Starter
88blaster
I am running a mag mount lil wilson antenna, I have a cheap SWR meter that I don't think works, I will check it out some time.
Silver Cherokee
post #9 of 13 Old 07-25-2007, 04:00 AM
Scrambler82
1982 CJ8
Don't wait forever, let us know... ???
Scrambler82
post #10 of 13 Old 07-25-2007, 10:28 AM Thread Starter
88blaster
I leave for england tommarro so I'm not real worried about my cb right now. I do it when I get back in 2 1/2 weeks. Then I ll let you guys know.
Silver Cherokee
post #11 of 13 Old 07-26-2007, 06:24 AM
Scrambler82
1982 CJ8
Wow, England, enjoy.
Scrambler82
post #12 of 13 Old 07-26-2007, 09:01 AM Thread Starter
88blaster
Thanks, I leave in an hour, I am going crazy...
Silver Cherokee
post #13 of 13 Old 07-28-2007, 01:50 PM
goatboy
Now, this I did not know: "Old elctronics dry out, especially if not used."
Tell me more...I've never heard of this concept...
goatboy is offline
Midland 5001 cb DeepJeep Audio, CB & Ham Radios, GPS, & Electrical 2 09-22-2008 07:15 PM
Midland Handheld CB scotiez Audio, CB & Ham Radios, GPS, & Electrical 7 09-21-2008 10:09 AM
Opinions on Midland CB? Sambox Audio, CB & Ham Radios, GPS, & Electrical 4 08-14-2008 07:00 PM
Midland Cb Radio jbpdog Audio, CB & Ham Radios, GPS, & Electrical 1 05-08-2006 10:52 AM
Midland 75-822 MSAND1977 Audio, CB & Ham Radios, GPS, & Electrical 4 03-22-2006 10:09 AM
