ohm impedence - JeepForum.com
Closed Thread
post #1 of 23 Old 12-21-2008, 07:40 PM Thread Starter
KodiakBuzz
ohm impedence
Hey guys another question,
I just bought the Cobra 25 wx st CB system and the 35 dollar PA powerhorn speaker from Radioshack. I am thinking about buying an amp to hook it through because apparently you also need an amp to make the powerhorn sound loud.
My question is, the pa speaker is
8 ohm impedence
350-9000mhz frequency response
110db MHZ output
50w rms power hoandling
100w Maximum power handle
can I just get any amp to fit it? or does it also need to be 8 ohms? I heard of a guy who bought 8 ohm amp but had 4 ohm speakers so it wouldnt fit. So, im confused.
Thanks
KodiakBuzz is offline
post #2 of 23 Old 12-21-2008, 09:53 PM Thread Starter
KodiakBuzz
Someone Tell Me, Im About To Go Buy A Sub And Amp Which Im Hopign Will Workkkkk
post #3 of 23 Old 12-22-2008, 06:25 AM
GCool
8 ohm is a high impendance speaker for a car. Will it work yes. the hard part will be to find a amp that makes any kinda of power @ 8 ohm. At the least you will find most amps will make less power at a higher impendance.
07 4 door X Unlimited
K&N , 2in BB , 33's
Kicker SS 5 1/4 components X2 ,Kicker ZX350.4 , Kicker Solo X 12 , Panasonic CDQ 800U, Sundown 3000D, NSB 90 X2
Thanks to the new sponsor Sundown Audio!
GCool is offline
post #4 of 23 Old 12-22-2008, 08:25 AM Thread Starter
KodiakBuzz
Oh, yea that 8 ohm impedance is solely my powerhorn pa. As for my speakers I have no idea what ohms they are. But is there a chance the amp might not be compatible with my speakers? I think theyre sony.... not that the brand name helps any.
post #5 of 23 Old 12-22-2008, 09:10 AM
GCool
are you hooking up a caraudio amp up to the 8ohm speaker? if so you wont have any problems other than not getting the max power out of your amp.
K&N , 2in BB , 33's
GCool is offline
post #6 of 23 Old 12-22-2008, 09:17 AM Thread Starter
KodiakBuzz
the amp is from audiofonics apparently from Pimp your ride, its attached to the custom sub box for 2003-2006 jeep behind the rear seat with JBL speakers . As for my speakers I have no idea what the ohm impedance is.
post #7 of 23 Old 12-22-2008, 10:07 AM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
Car audio amps are generally rated at 4 ohms. When you power an 8 ohm speaker with a 4 ohm amp the speaker will only receive about 1/2 of it's rated power. The RMS of the PA speaker is 50 watts which means you could probably get away with a 100 watt 4 ohm amp.
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #8 of 23 Old 12-22-2008, 10:11 AM Thread Starter
KodiakBuzz
oh nice. So if I ever have a difference in ohms between the speaker and amp, I shouldnt ever have compatibility issues just power issues right?
post #9 of 23 Old 12-22-2008, 10:15 AM
ChiliPalmer
Correct - but you don't really want to go the other way unless you have quality amps/speakers i.e. don't power 1 or 2 ohm speakers with a crappy amp or it won't last long - the amp has to be designed to sustain that load.
Forum!
post #10 of 23 Old 12-22-2008, 11:51 AM Thread Starter
KodiakBuzz
hmm. Say i have 4 ohm speakers, and a 4 ohm 1500w amp... what would you say... good bad?
On another note i got a free papaya from Ralphs the neighborhood grocery store. Clerk rang it up wrong by like 5 bucks and she just gave me a 100% refund and I kept the papaya. YEA
post #11 of 23 Old 12-22-2008, 11:56 AM
GCool
you just never want to go lower impeance than an amp wants to play.
btw congrats on the papaya !
K&N , 2in BB , 33's
GCool is offline
post #12 of 23 Old 12-22-2008, 12:15 PM
ChiliPalmer
You don't want to exceed the speakers rating of 50W so if you have a 4 channel 200W RMS amp you would be ok if you only send 1 channel to the speaker; but you wouldn't want to bridge 2 channels and send 100W to the speaker...
Forum!
post #13 of 23 Old 12-22-2008, 12:26 PM
chutta
Why do you need to hook up the PA to an amp? It's already rated at 110dB efficiency, one of the highest available likely due to the horn. Efficiency ratings are taken with only 1 watt input.
I'd try it as is, unless you want to talk to Tijuana from your driveway
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline
post #14 of 23 Old 12-22-2008, 01:50 PM Thread Starter
KodiakBuzz
whoa, so are you telling me with an adaptor I can just hook the pa up the my CB cobra 25 wx st and have the full 50w rms or 100w powder?
post #15 of 23 Old 12-22-2008, 02:03 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Sheesh, much ado about nothing. His PA speaker will not require many watts to drive it to full power output at all, all this worry about amps not putting out their entire wattage capability into 8 ohms is pretty meaningless. A small simple amp is all that is needed, no high-end audio amps need apply.
Jerry Bransford is online now
Closed Thread
Subwoofer impedence labeling question Slithering_Joe Audio, CB & Ham Radios, GPS, & Electrical 9 04-23-2008 11:15 AM
impedence on amps vs impedence on speakers JeepMKcomin Audio, CB & Ham Radios, GPS, & Electrical 9 01-02-2007 09:37 AM
