Off Road Lighting HELP! - JeepForum.com
post #1 of 2 Old 09-06-2011, 02:29 PM Thread Starter
ConnerJewell
I have two fog lights on the rear bumper of my 1995 YJ and they have both been destroyed, long story. Anyways I was looking to replace them but have a problem because i have no idea what kind the were or the wattage ect... All I know is that there was a wire coming from the jeep to one light, out that light to the other and then to the frame. Is there anyway i can test the wattage coming from the wire or something?? Im no electrician. Thanks
ConnerJewell is offline
post #2 of 2 Old 09-06-2011, 07:16 PM
JPNinPA
No you can't tell wattage from teh remnants. And it sounds like it wasn't wired effectively.
You describes lights wired in series. That is not an acceptable way. Could start a fire or you will not get enough light out for the wattage they were. One was likely a bit brighter than the other.
Anyway KC and some other companies make a nice back up light that you could wire into your back up lights. No matter what you do I hope you use a relay with separate power for the lights in parallel. You could use the existing back up lights as the switch power to the relay.
I have the KC version for 5 years and couldn't be happier with the amount of light. I placed the mounting bracket between the rear bumper and frame. The lights are above the bumper pointed down where I needed it.
Hope this helps.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
lights , wiring
Best Off-Road Lighting willhbauto General Jeep & Off-Road Equipment 20 04-02-2008 07:34 AM
off road lighting Sh4dowRac3r Audio, CB & Ham Radios, GPS, & Electrical 1 02-24-2007 09:53 PM
off-road lighting help jeep n00b Audio, CB & Ham Radios, GPS, & Electrical 6 09-26-2006 07:01 PM
Off road lighting on TJ? nikki Audio, CB & Ham Radios, GPS, & Electrical 0 02-21-2005 01:18 PM
