OEM Fog Light Connector 04 Wrangler. - JeepForum.com
post #1 of 7 Old 04-08-2010, 05:37 PM Thread Starter
JeepnBlake
Revised: Since I have found the information I needed, I'm going to make a quick guide for others about the OEM fog light differences between 97-04 and the 05-06.
97-04 fog lights are the OBEN style, they say so on the glass. These lights can accept the mesh stone guards, and the full face stone guards. These lights have the metal mounts.
05-06 fog lights are the HELLA style. They say so somewhere on the housing I forgot where. These can not use the mesh or full face stone guards, but you CAN order replacement glass for them. These lights have the plastic mounts.
Here is a broken fog light, this is the 97-04 OBEN stye.
Here's what the connector on the fog light looks like.
Here is the 97-04 connector on the Jeep.
This is the 05-06 Hella style fog light connector.
This is the 05-06 connector on the Jeep.
You'll notice that the connections merely switched roles between the two style.
97-04 OBEN the large connector is on the fog light, the smaller one is on the Jeep.
05-06 HELLA the small connector is on the fog light, the larger one is on the Jeep.
If you're looking to make a set of extensions, or adapters to run one style or the other on the opposite style jeep, then you must find a set of connectors.
The best locations to find these connectors are:
97-06 TJ Wranglers under the battery tray, and at the fog light connection. 03+ always have the Jeep connectors by the fenders.
93-98 Grand Cherokee ZJ battery sensors, literally under the battery tray attached to the sensor.
XJs Unsure of the year range, but again under the battery tray.
Durangos first generation durangos have these connectors under the battery trays as well.
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #2 of 7 Old 04-08-2010, 08:23 PM Thread Starter
JeepnBlake
Bumpity Bump
-Blake-
Build Thread:
Dad's Build Thread:
post #3 of 7 Old 04-13-2010, 04:01 PM Thread Starter
JeepnBlake
Found a source for these connectors.
Durango, Cherokee & Grand Cherokee (ZJ) all use this type of connector for the battery weight/temperature sensor.
-Blake-
Build Thread:
Dad's Build Thread:
post #4 of 7 Old 03-10-2011, 02:47 PM
BlackSCRunner
Where did you end up finding this connector? I'm looking for the same thing, but the other side
BlackSCRunner is offline
post #5 of 7 Old 03-12-2011, 11:53 AM Thread Starter
JeepnBlake
Here
-Blake-
Build Thread:
Dad's Build Thread:
post #6 of 7 Old 03-12-2011, 04:26 PM
BlackSCRunner
Here
I didnt see a link, but I ended up finding some mopar extensions on ebay and ordered them up. $25 shipped for the pair.
post #7 of 7 Old 10-02-2012, 12:53 PM Thread Starter
JeepnBlake
To clarify this a little bit, I ended up going through several junk yards to find this connector. You're best off going by yourself and pulling them out from under the XJ, ZJ or durango battery trays.
-Blake-
Build Thread:
Dad's Build Thread:
10 pin connector Jocko12 Audio, CB & Ham Radios, GPS, & Electrical 2 10-11-2009 11:11 PM
1990 wrangler headlights and tail light troubles ImpactFabWorks Audio, CB & Ham Radios, GPS, & Electrical 0 01-30-2009 02:00 PM
7 pin Trailer Connector for Wrangler J-Mox Audio, CB & Ham Radios, GPS, & Electrical 2 12-23-2008 12:05 PM
need help with light bar install on 05 Wrangler RI_WRANGLER General Jeep & Off-Road Equipment 3 06-30-2007 09:17 PM
Who makes a wrangler tail light antenna mount Gary Gill Audio, CB & Ham Radios, GPS, & Electrical 10 08-16-2005 06:10 AM
