O2 sensor wiring hell for 96 xj - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > O2 sensor wiring hell for 96 xj
Memorial Day Weekend Sale Starts Friday-Tuesday 10% off + All Bilstein shocks & struts - Lowest Prices Ever and RuffStuff Memorial Day Sale!
Unread 11-07-2012, 08:17 AM   #1
clab0603
I have a 96 xj and I bought a new o2 sensor. Problem is that the plug from the jeep got ripped off. Can someone help me with what wires go to what. Coming off the jeep is a: black n white, black n blue, tan n white, and a green and orange. Help needed please and thank you.
clab0603 is offline   Reply With Quote
Unread 11-07-2012, 06:27 PM   #2
gunner44
Will work on it, I have a 97-ZJ Factory manual.
gunner44 is offline   Reply With Quote
Unread 11-07-2012, 07:37 PM   #3
clab0603
Thanks for the help! Only problem is I have a 96 XJ.
Unread 11-07-2012, 07:44 PM   #4
gunner44
Well, nothing easy. For my 97,ZJ, 5.2,
Assuming it is the upstream Heated Oxygen sensor, (must be the same for the rear one if you have one), Draw a circle with a small box on the left side at 9-o-clock (box is the lock clip). Going clock wise
1 - dark green/orange - Is the auto shutdown relay output
2 - Black/ tan - Ground
4 - Black/orange- (you are calling a Tan/white)- ? It is the upstream heated oxygen sensor signal.
3- Black/Light Blue -Sensor ground.
On your drawing, lock clip pointed to the Left - Pin 3 is below pin 1, pin 4 is below pin 2.
Before connecting PM me. That Tan and White bothers me. I have someplace a check on this with a multimeter.
Unread 11-07-2012, 07:50 PM   #5
gunner44
Hi
Have you checked the Forum for the XJ.
Unread 11-08-2012, 06:33 AM   #6
clab0603
Yea! I literally searched everywhere just the colors vary from jeep to jeep. I saw one guy with same colors as me and I pm'd him but he never replied.
Unread 11-08-2012, 02:28 PM   #7
gunner44
The danger here is that you send the heater voltage to the pcm if you get this wrong. Without the wiring diagram I would do nothing. I would stop searching and ask on your Jeep Forum for someone with a factory manual or find one on E-bay.
Unread 11-11-2012, 12:27 AM   #8
SnowdogMarc
I can help you but I need more info...Which model XJ is it? Claasic, SE, Sport or Country edition.
The specs for the Classic are as follows
Pin 1 Dark Green/Orange...ASD Relay
Pin 2 Black/White............Common Ground
Pin 3 Black/Lt Blue...........Sensor Ground
Pin 4 Tan/White..............DNSTRM HO2S
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline   Reply With Quote
Unread 11-11-2012, 09:49 AM   #9
clab0603
Mine is a sport! And those are the colors coming off my jeep but I don't know what colors Match up!
Unread 11-11-2012, 02:34 PM   #10
SnowdogMarc
What style plug is on the sensor? Flat, Square or round?
If it's the square one this is what it should be...
This plug is off a 94 2.5 so the colors are not the same but the pin location will be.
l_______
/l ,[_____],
l---L -[]lllllll[]-
