noisy cb - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > noisy cb
RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineMemorial Day Sale at Under Cover Fabworks! 15% Discount o
Unread 11-09-2006, 09:44 PM   #1
TXjeep97
noisy cb
I read the sticky, but I'm wondering how many of you have to squelch the hell out f your cb during the day? I just got a $35 CB from walmart and a lil' wil antenna. During the day I have to put the squelch at about the 1 o'clock position (it only goes to about 5). Am I getting all this noise from it because it's a cheapie? It's not engine noise either cause it will do it with the jeep on or off. At night I can set the squelch to 10 o'clock. I also noticed that it happens near powerlines also. What do you guys suggest? Moving the antenna (its in the center of the roof right now) or what? Oh, the antenna has been tuned also.
TXjeep97 is offline   Reply With Quote
Unread 11-10-2006, 06:27 AM   #2
Scrambler82
Scrambler82's Avatar
1982 CJ8
Originally Posted by TXjeep97
I read the sticky, but I'm wondering how many of you have to squelch the hell out f your cb during the day? I just got a $35 CB from walmart and a lil' wil antenna. During the day I have to put the squelch at about the 1 o'clock position (it only goes to about 5). Am I getting all this noise from it because it's a cheapie? It's not engine noise either cause it will do it with the jeep on or off. At night I can set the squelch to 10 o'clock. .
Due to the sun's electification of the Ionosphere creates more noise on the CB, that is why at night you use less squelch.
Reason here is that the CB uses an AM signal and White Noise created by the power lines raises he!! with an AM signal.
Your CB sounds like it is working correctly.
Ltr
Scrambler82
Do it right the first time !
Scrambler82 is offline   Reply With Quote
Unread 11-10-2006, 08:27 AM   #3
SomeGuysName
One way of telling whether you're getting power noise (from the power going to the cb, not overhead powerlines)or antenna noise is to unhook the antenna with the radio on (dont key it up) If the noise goes away, it's being injected into your antenna system. Better coax will get rid of a lot of it. If it doesnt go away, you need to work on your power wiring.
But yes, there is a lot more ambient noise during the day than there is at night, the sun spots, more people talking...all kinds of stuff. A little bit of trivia...sun spots come and go in about a 11 year cycle. Every 11 years or so there are more of them than normal and it plays hell with CB's.
SomeGuysName is offline   Reply With Quote
Unread 11-10-2006, 11:36 AM   #4
TXjeep97
Well, last night i went out and found that the cb makes noise at night also. So i tried moving the antenna around and found that when I touched the antenna, the noise stopped. It's almost as if either the antenna is not long enough or it is not properly grounded. I thought wilsons were supposed to be good?
Unread 11-10-2006, 12:25 PM   #5
Ryuu600
Wilsons are good but all antennas need to be properly grounded and tuned.
/l ,[COLOR="Blue"][____][/COLOR],
[COLOR="Blue"]l---L –[/COLOR]0[COLOR="Blue"]lllllll[/COLOR]0[COLOR="Blue"]-[/COLOR]
()_) ()_)--o-)_)
'06 TJ X Blue w/dark khaki top, 4.0L, 6 spd, 3.73, 30x9.5R15 Wrangler GS-As mounted on Ravine wheels, Soft-top w/half doors, 4 100w ProComp Offroad lights(2 bumper, 2 windshied), Cobra 29 LTD w/4' Firestik, Custom rear storage box.
Ryuu600 is offline   Reply With Quote
