No power to amp? But capacitor does have power - Page 2 - JeepForum.com
post #16 of 19 Old 07-05-2013, 10:46 PM
xrunndonex
1994 ZJ
Originally Posted by PurpleTJ View Post
I installed my cap to get rid of the speaker whine.
Still no results. Jumped between the power and remote wire, and also jumped the cap.
Caps are bad on your charging system
xrunndonex is offline
post #17 of 19 Old 07-05-2013, 10:52 PM
xrunndonex
1994 ZJ
All fuses are good, all grounds are good. I've checked and re checked them all. I wish it were just settings in my head unit. It was working for months, then all of a sudden stopped. I never changed any settings.
Where are you grounded to remove the cap and just let the amp do its thing clean connections follow power wire to make sure no cuts in it. Follow the rcas to make sure there ok. Make sure it has a solid ground (I'm grounded on the frame) gains on amp set right? Is there lights on it when it works? It may be in protection mode. Make sure speaker wire is good. have a friend with a system? Take his amp out hook yours up and of it don't work your amp is done
post #18 of 19 Old 07-07-2013, 12:13 PM Thread Starter
PurpleTJ
Amp is grounded to the tub. Gains are set right. There are two lights on the amp: Power, and Protect. Neither will light up.
I have a buddy with an amp, and I thought of swapping them out yesterday. I might try that.
Say a speaker or RCA cable was severed/disconnected. That wouldn't cause my problem, would it? If the amp has power it should turn on, despite not being connected to speakers.
Purple Jeep Club member #8
PurpleTJ is offline
post #19 of 19 Old 07-07-2013, 02:01 PM
xrunndonex
1994 ZJ
Rcas not to sure may depend with amps I'll disconnect mine and see but speaker wires no. Just wasn't sure if your amp had lights lol
