new head unit and install questions - JeepForum.com
post #1 of 6 Old 09-22-2004, 12:39 PM Thread Starter
limecolbyjack
limecolbyjack's Avatar
i got a alpine head unit. how do i take out the factory one? i have a 2004 wrangler x. and what do i need to get this thing up and running? thanks -chris
limecolbyjack is offline
post #2 of 6 Old 09-22-2004, 12:45 PM
omnipseudo
omnipseudo's Avatar
To remove the stock...
Take a standard screwdriver and pry up the little top vent where the defrost comes out of. It runs the length of the Jeep. There are 2 screws right under the defrost vents. and then remove your ashtray, theres a screw back there. Once youve removed the 3 screws, give the molding a good few tugs and itll pop out with some encouragement. unscrew the 2 bolts in the radio and pull it out. Unplug the radio antenna, and wiring harness. Youll need to buy another wiring harness that will fit the Jeeps existing one. Youll then soder/heatshrink the wires from the new harness to the apline harness.
2000 Wrangler TJ Sport
Pics coming soon...
omnipseudo is offline
post #3 of 6 Old 09-24-2004, 10:51 AM Thread Starter
limecolbyjack
i dont have a ash tray in my 04, so where may the other bolt be at? thanks -chris
post #4 of 6 Old 09-24-2004, 11:43 AM
SirGCal
SirGCal's Avatar
You might be able to pop out that plastic plate there or there might not be a screw there at all. I've never done a non-smoker's group model so I'm not sure really...
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #5 of 6 Old 09-27-2004, 08:38 AM
pmh118
pmh118's Avatar
Chris,
I just swapped out my head unit in my 2004 Wrangler last week, so I may be able to give you a few pointers. I'm not exactly sure where the ash tray is located on older models, but it is not on the dash in the 2004's. It is actually just a round ash tray that is placed in what is basically another cupholder on the center console. You don't need to do anything with the ash tray (or the lack thereof) at all.
I'll try to recap some of omnipseudo's steps per the 2004 model:
1) Remove the long, skinny trim piece that is located near the windshield. It is almost as wide as the whole windshield. Just pull up on it and it should pop right out.
2) Remove the two screws that are located at the top of the bezel (surrounds the vents, radio and HVAC controls). You should be able to see these screws provided that you removed the trim piece in step 1. Carefully pull the bezel outwards and upwards and it should come out.
3) Remove your glove box by opening it and detaching the nylon string piece that holds it in place.
4) Reach through your glove box and behind the radio to remove the bolt (don't remember the size) that is located on the lower, right rear portion of the head unit. This step is by far the most difficult just because it's such a small/awkward space to reach your hand.
5) Detach the factory wiring and antenna from the rear of the radio.
If memory serves me correctly, that's about it. Good luck!
pmh118 is offline
post #6 of 6 Old 09-27-2004, 02:23 PM Thread Starter
limecolbyjack
cool thanks guys, now i have a alpine deck in the TJ, i need to upgrade the rear speakers now. again thanks -chris
Do YJ's need an Install Kit for a head unit? johnsoninc86 Audio, CB & Ham Radios, GPS, & Electrical 1 01-22-2009 03:50 PM
97 sahara head unit install bluetj04 Audio, CB & Ham Radios, GPS, & Electrical 1 01-10-2009 11:38 AM
TJ Head unit install..... BloodThirsty Audio, CB & Ham Radios, GPS, & Electrical 3 10-15-2008 10:12 AM
head unit install Wrangler11 Audio, CB & Ham Radios, GPS, & Electrical 7 12-24-2006 10:22 PM
Help! Trying to install new CD head unit! Free2Play Audio, CB & Ham Radios, GPS, & Electrical 12 09-09-2002 09:13 PM
