Need recommendation for Sub/Amp/Speaker
#76 | ||
'89 YJ, 355ci small block, NV4500, 31's for now, lots of custom fabbed "stuff"... '06 Duramax, 6" Superlift, 35" Toyo's, 18" KMC's, Linex bedliner, AMP Research steps, Kicker amps & speakers, JVC DVD touchscreen Firefighter/EMT |
#77 |
Considering theft and everything else a wrangler goes thru buying your original equipment used is a good school of thought. This way you haven't invested a lot you can spend more on making your sub box and if it gets wet and dies then you don't have to worry too much about it.
The sub you'll be using is a good everyday sub to start with, if it dies the volume of the sub box will work with virtually any entry/mid-level sub on the market. Make sure that you use a volume calculator to make your box. Additionally the 2.5" for excursion (between sub and floor) should be fine with that sub. Don't make your box square tho...always go with a rectanlge or "shape" for optimal performance. http://www.rockfordfosgate.com/rftech/box_wizard.asp They also have a link to help you with wiring the sub: http://www.rockfordfosgate.com/rftech/woofer_wizard.asp |
#78 |
good links thanks!
#79 | |
YEs, I meant no need to double up the MDF.
Sir G. Cal - 2k Sahara TJ Living and loving on borrowed time. Life with Multiple Sclerosis. My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more. Quote:
#80 | |
Dave
NRA Life member Square Headlights group member #222 Armed Forces Jeeps group member #65 United States Air Force group member #12 Guns and Jeeps group member #10 Ron Paul Jeepers group member #7 |
#81 | |
#82 |
ok here is a question. Should I worry about woofer displacement? The net internal volume is supposed to be .75 should I add like .10 for the sub? I can't seem to find anything on google in regards to this. Or would it make that big of a deal if I didn't. Also Polyfill, I have read start at filling the box about 10% and see how it sounds and go from there. Do you stuff it in there or fill it in loosely. I would probably screw the 10% and fill it like half full to begin with. Let me know your guys' input on this thanks!
#83 |
i would add in the .1 for displacement of the driver but it really isnt that much. close enough is good enough for me. and poly fill is for if you have to make a box too small it ricks it into thinking it is largr by dampening the back wave or something. the general rule is 1 lb of fill to 1 ft^3 and it should be loosely filled. if its packed its just taking up space. but if its the right size you shouldnt need any
-James Got to love an ORVIS guy... IRO 5.5", Front LA & Double Sheer TB, Rear Adjustable SA and TB, JKS Quick Discos, DT8Ks 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs JCR Stage 2 Sliders, IRO Trans Skid |
#84 | |
The specs for exact driver displacement can be found by the manufacturer, but unless your going for competition perfection, the box doesn't have to be that exact. But yea, subtract that from the volume you've calculated to see the effective size of your box plans.
For example, if your box was 14x12x8 externally using 3/4" MDF, the box would have an internal volume of 0.494 ft^3 (12.5x10.5x6.5). If the sub ate up 0.06ft^3 of that, the resulting box would be 0.434 ft^3. Polyfill then would make the box act larger. Just a little would take the harshness out, I usually use at least a little bit, especially in a square box since it helps soften the wave pattern, and filling the box (loosely, as said about 1lb per cubic foot) could make it act as though it were 3-5% larger. If you build the box too large or perfect, obviously then do not use any unless it needs tuned slightly for the vehicle's acoustics.
#85 | ||
However, Kenwood has much worse electronics than Alpine. If that wasn't the case, I would not have been replacing 10 Kenwoods to 1 of ever other brand out there. One example was a guy that came in with a $1400 Kenwood stealth unit a few years ago complaining about his bass. Muddy as hell. Swore he wanted new amps and subs since this new unit couldn't possibly be the cause. I ran some testing quickly and told him the unit was indeed the cause. I tried my best to tweak the unit to it's maximum but couldn't get it past that wet-fart stage. (this particular unit was exceptionally poor, even for Kenwood). I finally showed him on the scope how I knew it was the unit. He sent it back for an exchange. I received the new one, same result, though better. I asked him to let me show him something; slapped in a mid-level $300 Alpine that did more than his overpriced Kenwood could ever dream. Set it up properly and boom, crisp, clear and accurate bass (even with his sad excuse for bass equipment honestly). My guess is you probably never set them up properly. Perhaps had the Alpine internal crossovers set too high or EQs set to flat or just never set the XM control system (not the sat radio). They (Alpine) do not fake any of the signal like Kenwoods do. Out of the box, the K's Boost the signal to try to compensate for the automobile's native inaccuracies. (this was why the Kenwood sounded so muddy) Alpines won't do that until you tell them exactly how to do that. So they will sound flatter out of the box until you tweak them. They are not going to try to guess a setting for every vehicle. Same goes for Eclipse and Clarion. Even Sony, another one of my 'never use' brands doesn't do that. Still, you are entitled to your opinion. If you like Kenwood over Alpine, more power too you. However their electronics being superior, they are not. Not even close in their highest equipment. Although I heard that they had started to remove their sound shaping from their equipment, but they did it for so long, I haven not even considered Kenwoods for many years so I do not keep up with them any longer. They might be peachy (or at least much much better) today but it's like being spit on by a camel too much. Eventually you just stay away from it. I would build a competition rig with Dual or Jenson (who's product has actually come around a ton in recent years) well before ever going to Kenwood again. But that is MY opinion. And as for competition rigs; saying you won't win sound competitions in a Jeep; poppycock! ![]() http://www.sirgcal.com/2ktj/ God I was fat in this picture... And UGLY! Shesh.. Someone just photochop me out of my own picture would ya?
#86 | |
#87 | |
almost 80 degrees here today... windy as heck though. wanted to take the Honda out on a cruise but it's a bit blustery.
#88 | |
Ok so I have been toying with the idea of not buying that woofer and only the amp. IF and I mean if I were to buy a new sub what should I get. The amp is 200x1 4ohm 300x1 2ohm. I wouldn't spend more than $100. Would want the most bang for my buck. Let me know what you guys think... |
#89 | |
Sorry.
![]() for an amp like that, there are tons.. pretty much depends on what your ears like. You could get a 4-ohm single coil sub and run it direct (cheapest option) or a DVC 4-ohm sub and run it 2-ohms. For example, an MTX Thunder4500 T4510-04 or Infinity Reference 1050w or MTX JackHammer JH4510-04 or (the list really does go on and on and on...) or JL Audio 10W1v2-4 would run just fine. Any 4-ohm 200-300W RMS sub. Or 4-ohm DVC, again huge list...
#90 |
or a pair of rockford p1s ( http://www.sonicelectronix.com/item_8758_Rockford+Fosgate+Punch+P1S410.html ) or kicker CVs ( http://www.sonicelectronix.com/item_3447_Kicker+05C104.html ). something small and single 4 ohm coils rated at 150 a sub if you want some more surface area. but i think you might lose some sound quality (IMO) and it would require a box 2x the size. but both those listed are a good match for the amp and should be 100-120 new.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
