Need help hooking up a Firestik CB Antenna - JeepForum.com
post #1 of 8 Old 02-14-2012, 10:43 AM Thread Starter
hfa8592
I bought a small Uniden CB radio and a firestik antenna off craigslist and now can't figure out how to wire up the firestik. D'oh!
The antenna has a bolt in the bottom where you are supposed to hook the cable up.
I had a fab shop weld a tab for the antenna onto my rear bumper, crimped an eyelet onto the end of the cable, then bolted it to the bottom of the antenna, which is bolted to the tab on the bumper. Since the tab was welded onto the bumper, I am certain it's grounded. But, I can't get any reception at all. I have gone out on the highway and scanned all the CB channels, adjusted the squelch and rf gain and just get static.
I have checked Firestik's website and even called them (since they are right here in Phoenix), but I just can't understand their schematic diagrams.
I know that I have the radio itself hooked up properly....
Can anyone give me a simple explanation of how to wire up the friggen firestik antenna?
Thanks in advance for any guidance you can provide!!!
Scott
Scott
'93 YJ, 4" spring lift, 4.0 I6, NV4500, Atlas II, SYE, Currie/Ford 9" rear axle, ARBs front & rear, Kilby OBA, 33" Wrangler MTRs, custom cage, custom bumpers.
hfa8592 is offline
post #2 of 8 Old 02-14-2012, 12:24 PM
DuncsJeeps
DuncsJeeps's Avatar
2006 XK Commander
I have a Firestik. This is what I used to mount it...
What are the rest of the components you bought with it? where are you having problems (radio end or antenna end)?
There are instructions for all of these on the firestik website.
I hope this helps
Coax http://www.firestik.com/Catalog/k4-8r18.htm
Mount http://www.firestik.com/Catalog/SS-204.htm
Antenna http://www.firestik.com/Catalog/FL3-FL4.htm
Spring http://www.firestik.com/Catalog/SS-3M.htm
DuncsJeeps is offline
post #3 of 8 Old 02-14-2012, 02:52 PM
Skyryder
There has to be a isolation insulator washer, usually plastic but sometimes made of fiber installed between the base of your antenna and the mounting tab.
While you need a good ground for the mount, the ant itself is not grounded.
The shielded (outer) section of the coax should be grounded at the mount,
The center portion of the coax should be attached to the antenna's (ungrounded) base or stud.
Skyryder
'97 Black TJ - 4 banger - 5 speed
Proud user of the "K.I.S.S." Principle.
Black Jeep Society #264
Skyryder is offline
post #4 of 8 Old 02-14-2012, 04:16 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
You need:
  • CB Antenna
  • CB Antenna mounting stud
  • CB Antenna bracket of some type
  • CB antenna coax cable that matches your CB antenna mounting stud
CJ7-Tim is offline
post #5 of 8 Old 02-15-2012, 08:14 AM Thread Starter
hfa8592
Thanks, that all explains what I am doing wrong. I find those instructions on Firestik's website to be pretty confusing. I didn't isolate the antenna from the ground and the antenna didn't come with some of these parts. Any idea where I can get an isolation insulation washer like that?
Thanks again guys for your help...
Scott
hfa8592 is offline
post #6 of 8 Old 02-15-2012, 09:24 AM
CJ7-Tim
CJ7-Tim's Avatar
Any CB shop, on the Google or Amazon.com , most truck stops, any Ham Radio store, and some Radio Shack stores. You will have to buy a complete stud assembly.
CJ7-Tim is offline
post #7 of 8 Old 02-15-2012, 09:31 AM
DuncsJeeps
DuncsJeeps's Avatar
2006 XK Commander
If you didn't get the plastic isolation washer with your parts. You should be able to contact the reseller and they will probably just send you one in the mail.
If you don't wan to wait for that. You could probably also get it from your local hardware store. It's just pretty much just a washer that is durable and not metal.
post #8 of 8 Old 02-23-2016, 03:05 AM
-Syntax-
2007 WK
When I installed my first CB radio onto my WJ I had the same problem, used a Firestik kit ss204a and a Firestik antenna that had the ground strap at the bottom. Ended up taking it to a Ham radio shop. Right away they noticed that I was missing the white plastic insulating washer. Told me my entire antenna was being grounded. They added the washer, they didnt connect the ground wire that was spiraled around the antenna. But my radio worked great for years..
I put a 2' extension with a coupler at the front so I could add a SWR meter inline and remove it without changing the length of the cable.
-Syntax- is offline
antenna , firestik , radio
Firestik 2m antenna clb251 Audio, CB & Ham Radios, GPS, & Electrical 1 11-27-2009 01:21 AM
which firestik antenna do you recommend? MEinSoCal Audio, CB & Ham Radios, GPS, & Electrical 15 04-15-2009 09:40 AM
using firestik antenna as radio antenna? got_4_lo Audio, CB & Ham Radios, GPS, & Electrical 9 01-11-2006 07:39 PM
Firestik Antenna Mount Corran.R9 Audio, CB & Ham Radios, GPS, & Electrical 5 11-03-2005 07:17 AM
How to tune a Firestik KW antenna? ecrab3 Audio, CB & Ham Radios, GPS, & Electrical 6 06-20-2003 09:31 PM
