Need Help! Emergency Siren in Jeep Liberty 2005 - JeepForum.com
post #1 of 4 Old 08-20-2009, 10:37 PM Thread Starter
akehl
2005 KJ Liberty
I have a Jeep Liberty Sport 2005 and am looking to install a Siren. Two issues:
1. Where would you recommend placing the siren. Their is not much free space in the engine compartment.
2. Would you hook it up directly to the battery? This siren model has no ground wire just the hot (+) and cold (-).
Thanks in advance. Also FYI I am installing this siren because I am a volunteer medic with a Vermont based rescue squad and if we want to be anywhere aside from quarters we are required to.
akehl is offline
post #2 of 4 Old 08-20-2009, 11:03 PM
Veeb0rg
1995 XJ Cherokee
the "cold" wire is the ground wire.
Veeb0rg is offline
post #3 of 4 Old 08-21-2009, 04:47 AM
CMARJEEP
CMARJEEP's Avatar
You can't just hook it up straight to the battery without going through some kind of switch. Also, what is going to be your control? Most sirens include a control box (what actually has the siren noise), and the speaker (which projects the siren noise). So you would hook the speaker up to the control box and then have the control box hooked into some type of power source.
Could you give us a little more specifics of what kind of siren you have right now? Sounds like you might want to get a professional to install this.
This would be considered the actual siren (control box):
This would be the speaker that you hook to the siren:
CMARJEEP is offline
post #4 of 4 Old 08-23-2009, 10:47 PM
GEMSjeeper
Die Spammer Scum!!!!!!!
GEMSjeeper is offline
2005 Jeep Liberty Valve Locks coffeekid Engines & Drivetrain 3 09-04-2009 07:06 PM
2005 liberty radio in a 93 Cherokee? jw190m Audio, CB & Ham Radios, GPS, & Electrical 3 07-20-2009 08:29 AM
15 inch rim on 2005 liberty abomb1701 Tires & Wheels 0 04-20-2009 03:01 PM
PA/siren specs and ideas will_m Audio, CB & Ham Radios, GPS, & Electrical 8 08-14-2006 03:49 AM
