Need help with attaching CB antenna (SO239 connector?) - JeepForum.com
post #1 of 24 Old 04-26-2014, 10:02 PM Thread Starter
fantomas
So I'm getting the parts together to install a 102" whip antenna. It'll be attached to a Hustler SSM-1 ball mount. I bought an 18' RG-58A/U cable with two PL-259 connectors. The ball mount appears to have a lug for connecting to the coax. I've searched pretty extensively but maybe I'm using the wrong search terms. Is there an adapter that has I guess an SO-239 that goes to spade terminals? Or do I need to buy a different cable? Or is it as easy as chopping off a PL-239 connecter and soldering on some short wire and spade connectors myself?
fantomas is offline
post #2 of 24 Old 04-27-2014, 09:53 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
It's that easy, cut off the PL-259, strip back the insulation, and put some crimp rings on the coax cable bare copper wires.
CJ7-Tim is offline
post #3 of 24 Old 04-27-2014, 10:52 PM Thread Starter
fantomas
Thanks, that's exactly what I needed to hear. I know just about absolutely nothing regarding CB's so I didn't want to fubar anything with it.
fantomas is offline
post #4 of 24 Old 04-28-2014, 07:12 AM
turbogus
1978 CJ5
Don't forget to check your SWR after you get everyting hooked up. My 102 stainless had a flat 1/1 but I'm thinking I got lucky.
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #5 of 24 Old 05-18-2014, 10:40 PM Thread Starter
fantomas
Quick follow up question: Is the braided outer shield wire grounded to the vehicle body or does there have to be some sort of isolation for it?
fantomas is offline
post #6 of 24 Old 05-19-2014, 06:39 AM
prerunner1982
1993 XJ Cherokee
The outer braided shield is grounded to the body through the antenna mount.
Jon
1993 XJ Sport 2 door 4x4
1997 XJ Sport 4 door 4x2- RIP 6/6/16
2000 XJ Sport 4 door 4x2
prerunner1982 is offline
post #7 of 24 Old 05-19-2014, 07:20 AM
turbogus
1978 CJ5
No harm in protecting it with dielectric grease or encasing in heat shrink tubing though.
turbogus is offline
post #8 of 24 Old 05-22-2014, 01:52 PM
capt205
1983 CJ7
Solder a PL-259 and Ring Connectors to RG-8X (Min…: http://youtu.be/ABO45xFZCv8
capt205 is offline
post #9 of 24 Old 05-29-2014, 03:26 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
102" is good for RF but bad for many trail rides. In fact, out here in the old west many formal 4x4 events specifically prohibit the long whips. Instead i use a 19 inch tall 2meter/440 uhf antenna for all my comm needs.
god luck
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #10 of 24 Old 05-29-2014, 07:00 PM
dodge16vrt
Interesting....Why would they prohibit the best type of antenna?
dodge16vrt is offline
post #11 of 24 Old 05-29-2014, 09:02 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
Reasons are not known. Likely a safety issue. See many rigs with the tip secured over in an arc. Be interesting to do an antenna performance analysis with up v. looped over. But the formal, larger events require a tech inspection to proceed and a 102 will get the no go. I can imagine a long tip swinging to and fro potentially injuring obstacle spectators, more so on a tight trail. But I don't make the rules.
Shameless plug: getting a ham license is uber-easy and offers a vastly superior world for trail commo
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #12 of 24 Old 05-30-2014, 10:05 AM
prerunner1982
1993 XJ Cherokee
Exactly.. I have had mine lay over and almost touch the car next to me in high winds, I can only imagine hitting a ledge, popping the front of the Jeep up on it, and my antenna whipping around. It has a long reach and would leave a mark.
Yes sir... Agreed.
Jon
post #13 of 24 Old 05-30-2014, 10:42 AM
dodge16vrt
I can see maybe getting tapped with the antenna but I think that is the least of your worries when you are off roading, lol.
post #14 of 24 Old 05-30-2014, 11:17 AM
CJ7-Tim
CJ7-Tim's Avatar
Spectator safety is the reason 102" whips are not allowed.
CJ7-Tim is offline
post #15 of 24 Old 05-30-2014, 01:07 PM
prerunner1982
1993 XJ Cherokee
Not your safety... as Tim said the safety of those watching you.
Jon
