Name that part - JeepForum.com
post #1 of 19 Old 07-27-2013, 01:35 PM Thread Starter
Rican142
Name that part
So this is out of my 1964 F-100 what is it?
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #2 of 19 Old 07-27-2013, 01:38 PM
mike_breaker_5
temp sensor?
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #3 of 19 Old 07-27-2013, 01:57 PM
mike_breaker_5
looks similar but not identical.
maybe it's an oil pressure switch.
post #4 of 19 Old 07-27-2013, 02:58 PM
jjjk
Looks like a brake light switch.
jjjk is offline
post #5 of 19 Old 07-27-2013, 03:05 PM
mike_breaker_5
i thought that too... this is a pic of the brake light switch for that truck.
what motor is in this truck? rockauto has like 5 diff motor options for a '64 f100
post #6 of 19 Old 07-27-2013, 03:06 PM
mike_breaker_5
where in the truck was it mounted?
post #7 of 19 Old 07-27-2013, 03:33 PM
jjjk
I still think it is a brake light switch. The wire connectors are not stock and that leads me to believe that it is a substitute switch for the original factory switch. I'm not sure enough to place a bet on it though.
jjjk is offline
post #8 of 19 Old 07-27-2013, 04:13 PM Thread Starter
Rican142
262 I6 (not the original motor)
It's not mounted, just dangling there
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #9 of 19 Old 07-27-2013, 04:24 PM
mike_breaker_5
oh... so it's dangling on the interior? i thought you were just holding it there to show it. lol i would tend to agree with jjjk then. either like a door light switch, brake light switch, or a clutch safety switch.
post #10 of 19 Old 07-27-2013, 04:56 PM
2jhanna
does the white center plunger push in (spring loaded) ?
if so, some kind of switch, instead of a sensor.
jhanna
denton county, tx
2jhanna is online now
post #11 of 19 Old 07-27-2013, 04:57 PM
streetglideok
2005 KJ Liberty
Can't be a clutch safety switches, they had no such sissy switches on those old trucks. Its obviously a plunger style switch, so I would say it has to be a brake light switch. Would mount under the dash, above the brake pedal. If all works correctly, your brake lights should be on when the plunger isn't pushed in.
streetglideok is offline
post #12 of 19 Old 07-27-2013, 05:03 PM
mike_breaker_5
i know they didn't put them in older vehicles... but... since it looks like an addon, i had thought that for some reason or another it may have been added. just a thought. i would lean towards the brake light switch as well knowing the positioning of where it was hanging.
post #13 of 19 Old 07-27-2013, 05:45 PM
streetglideok
2005 KJ Liberty
On those old vehicles, everything looks like an add on,lol. Without being thereto see, it could be something else, heck even some redneck starter switch or horn button.
post #14 of 19 Old 07-27-2013, 08:03 PM Thread Starter
Rican142
No, that thing doesn't compress, and if it does it's jammed
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #15 of 19 Old 07-27-2013, 08:15 PM
beefcake3
I think you might want to post this question on http://www.killbillet.com/
beefcake3 is offline
