-   Audio, CB & Ham Radios, GPS, & Electrical (http://www.jeepforum.com/forum/f20/)
-   -   Name that part (http://www.jeepforum.com/forum/f20/name-part-1554324/)
Rican142 07-27-2013 12:35 PM
Name that part
1 Attachment(s)
So this is out of my 1964 F-100 what is it?
mike_breaker_5 07-27-2013 12:38 PM
temp sensor?
mike_breaker_5 07-27-2013 12:57 PM
https://www.rockauto.com/getimage/ge...03-0&width=450
looks similar but not identical.
maybe it's an oil pressure switch.
https://www.rockauto.com/getimage/ge...62-0&width=450
jjjk 07-27-2013 01:58 PM
Looks like a brake light switch.
mike_breaker_5 07-27-2013 02:05 PM
http://www.rockauto.com/getimage/get...Airtex/3D5.jpg
i thought that too... this is a pic of the brake light switch for that truck.
what motor is in this truck? rockauto has like 5 diff motor options for a '64 f100
mike_breaker_5 07-27-2013 02:06 PM
where in the truck was it mounted?
jjjk 07-27-2013 02:33 PM
I still think it is a brake light switch. The wire connectors are not stock and that leads me to believe that it is a substitute switch for the original factory switch. I'm not sure enough to place a bet on it though.
Rican142 07-27-2013 03:13 PM
262 I6 (not the original motor)
It's not mounted, just dangling there
mike_breaker_5 07-27-2013 03:24 PM
oh... so it's dangling on the interior? i thought you were just holding it there to show it. lol i would tend to agree with jjjk then. either like a door light switch, brake light switch, or a clutch safety switch.
2jhanna 07-27-2013 03:56 PM
does the white center plunger push in (spring loaded) ?
if so, some kind of switch, instead of a sensor.
streetglideok 07-27-2013 03:57 PM
Can't be a clutch safety switches, they had no such sissy switches on those old trucks. Its obviously a plunger style switch, so I would say it has to be a brake light switch. Would mount under the dash, above the brake pedal. If all works correctly, your brake lights should be on when the plunger isn't pushed in.
mike_breaker_5 07-27-2013 04:03 PM
i know they didn't put them in older vehicles... but... since it looks like an addon, i had thought that for some reason or another it may have been added. just a thought. i would lean towards the brake light switch as well knowing the positioning of where it was hanging.
streetglideok 07-27-2013 04:45 PM
On those old vehicles, everything looks like an add on,lol. Without being thereto see, it could be something else, heck even some redneck starter switch or horn button.
Rican142 07-27-2013 07:03 PM
No, that thing doesn't compress, and if it does it's jammed
beefcake3 07-27-2013 07:15 PM
I think you might want to post this question on http://www.killbillet.com/
The time now is 07:46 PM.
