My idea for a low cost system in my TJ. - JeepForum.com
post #1 of 3 Old 12-09-2007, 08:21 PM Thread Starter
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
So I have no real knowledge about sound systems.
I'm looking to upgrade and possibly put an Amp and sub in but I don't want to put a large box. It's a Jeep and It doesn't have to be amazing, I would just like a little more. I would like to keep my factory head unit (I guess that's what it would be called). I would like to keep it to cut the cost as well as keep the factory look to keep people from stealing it all. I would prefer to make it as hidden as possible.
My idea is to re gut the inside of the factory center console and hopefully put a small amp in there. Not sure how much room it would give if enough and leave some small amount of room for storage.
My thought for the placement of the sub is probably under the passenger seat. It might need a seat riser which would my girlfriend because she has trouble seeing over the Dash cage bar as it is.
My other idea is to mount the amp under one front seat and the sub under the other front seat.
I usually don't run a back seat so putting the amp and sub under that doesn't work.
Also what about marine grade units?
I would plan to make a surround for the sub as well. Not sure if there would be enough air space, but just throwing out ideas.
As for the Jack, I would either leave it where it is or mount it on the driver side or on the driver wheel well.
All these are ideas and i'm not sure they would even work.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #2 of 3 Old 12-10-2007, 02:24 AM
Mech
if youre going small, id recommend instead of raising the pass seat, put an 8" sub in the console and put the amp under the pass seat.
Mech is offline
post #3 of 3 Old 12-10-2007, 07:37 AM Thread Starter
JeepRocks86
That's probably a better idea. Good thinking.
For Sale:
Full Range Audio System, I had an Idea... bman9089 Audio, CB & Ham Radios, GPS, & Electrical 36 01-28-2008 05:05 PM
How much did yours cost? Willys '05 Tires & Wheels 13 05-17-2006 11:58 AM
Good idea? Bad idea? (CB) asc Audio, CB & Ham Radios, GPS, & Electrical 1 07-28-2004 07:48 PM
Who has the best system??? Please describe in detail what your system includes+ model jeepcj7 Audio, CB & Ham Radios, GPS, & Electrical 22 06-14-2004 08:34 PM
What should it cost? TJs96XJ Engines & Drivetrain 1 10-14-2002 05:03 PM
