my fiance's 2010 grand cherokee - JeepForum.com
post #1 of 8 Old 04-28-2014, 08:41 PM Thread Starter
jamiejamesjr
It all started with a right rear brake light out and then the rear signals went. Now the front signals still work however they flash faster than normal indicating a bad relay maybe? I'm okay with troubleshooting mechanical but electrical I have a lot to learn. Any advice or suggestions would be greatly appreciated!
Cheers
jamiejamesjr is offline
post #2 of 8 Old 04-29-2014, 03:12 AM
JPNinPA
When one light is out the others will blink faster. If changing the bulb doesn't work check the ground of the failing signal.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #3 of 8 Old 04-29-2014, 12:25 PM Thread Starter
jamiejamesjr
Right on thanks...I was hoping that too...do I need a diagnostic for ground faults or just a visual inspection and where are the ground wires found?
post #4 of 8 Old 04-29-2014, 02:01 PM
strvger01
1966 CJ5
visual should do the trick really. if it's in a place you can't see easily, then you might have to use a meter to check it.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline
post #5 of 8 Old 04-29-2014, 02:15 PM Thread Starter
jamiejamesjr
So the ground can be seen near the lens where the wire harness ends or trace it back...I'm not sure how to visually check for ground faults as far as where to look...I can easily get a diagnostic at the local parts store...probably the most accurate method I assume?
post #6 of 8 Old 04-29-2014, 06:29 PM
JPNinPA
Trace the wire back. You could just remove the screw, use sandpaper to shine up the connection on he body and connector.
JPNinPA is offline
post #7 of 8 Old 04-29-2014, 06:56 PM Thread Starter
jamiejamesjr
Got it thanks...liking this forum as a newbie...much thanks going out to everyone and their help...and I love all of my five Jeeps!
post #8 of 8 Old 05-11-2014, 03:48 PM Thread Starter
jamiejamesjr
Took the advice...just changing out the brake light bulb took care of all the other issues...thanks again for all your help guys!
Cheers
